» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 01-13-2007, 04:10 PM   #1 (permalink)
omeyhomey
Date registered: Jun 2003
Brushed Aluminum AMG pedals.... FINALLY installed them! (Writeup + pics)
Hey guys,
FINALLY... after 4 months of these pedals sitting on the mantle i finally decided to install them b/c i was getting sick of looking at them in my room. Here is the basic writeup of the install with pics and etc.
Materials necessary:
- scissors
- power drill
- 1/8th to 5/32 drill bits
- pencil
- allen wrench (i think 2.5mm)
- grocery store paper bag
- and hardward provided w/ pedals
- All necessary safety goggles & gloves & etc (always safety first guys!!) a drill bit actually snapped on me so i was lucky i was wearing my goggles)
Step 1:
First take off the rubber pedal pads, they come right off except for the gas pedal one, you can either disassemble the gas pedal (NOT recommended) or just cut the bottom backside portion with some scissors.
Step 2:
Take the drivers side floor mat out of the car and put grocery bag underneath to protect carpet from the falling metal flakes. Put the aluminum pedal covers onto the stock bare pedals and mark through the holes with a pencil to see where the holes are, then remove the pedals
Step 3:
To install the foot rest pedal (far right) its VERY simple, all you do is screw them in by hand w/ a phillips head screw driver directly into the thick carpet, takes about 30 sec.
step 4:
I started with the E-brake pedal first since its the smallest and easiest to line up. Just drill the pencil marks u made earlier and then slide the bolts through and put washers on the backside then the nuts and tighten w/ allen wrench.
Step 5:
The gas pedal is the easiest of the pedals u need to drill b/c its the only one thats plastic (E-brake & brake are both hardened steel as required by law... great haha). really you will only need to drill 3 b/c the top left hole will actually be outside the plastic pedals dimensions but it is still functional once you put washer on the back side, it will still add further support to the pedal). On a side note, on this one you really onlly need to put washers on the top holes, they won't fit on the bottom ones so just use nuts & 1/8th bit, smallest you can use to pass bolt through).
Step 6:
Brake pedal... this is the toughest of them all. you have to align all 4 holes on a STEEL brake haha, you will have fun with this one (and by fun i mean say alot of curse words and have to go back another 1-2 times to widen holes a bit or make them bigger). once u have finally gotten all the holes drilled pass the bolts through, washers on back side, then nuts like the rest of them.
Step 7: Finally go back and tighten all of them with allen wrench and then start to clean up. If you used grocery paper bag it will make cleanup ALOT easier but you will still have to clean up with a shop vac (which i did, they are only like $22-25 at lowes).
step 8: after a week or a month you may have to go back and tighten the bolts one more time for good and then they should remain tight for good. Oh and of course... Enjoy the pedals!!
Summary:
Difficulty: As far as interior mods go this is probably a 6/10 or 7/10, but overall is really only like a 4/10. Its more frustrating & time consuming than hard just b/c of the awkward tight spaces you have to work in. I know there are ones that u can just slide on but i wanted pedals that were truly unique & rare and i think these really add to the interior giving it that $80k car feel. I got these off ebay for $99 (for the pedals & shift knob & special edition plaque) and $25 shipping. But after selling my stock shift knob, everything really only came out to about $60 so u can save quite a bit of money.......
Anyways until the next mod...
The One, The Only,
~OmeyHomey~
omeyhomey is offline   Reply With Quote
Old 01-13-2007, 05:50 PM   #2 (permalink)
1 BAD BURB
1 BAD BURB's Avatar
Date registered: Aug 2006
Vehicle: 96' Suburban, 01' E55, 98' C5, 06' GSXR 1000
Send a message via AIM to 1 BAD BURB
awesome mod Omey! wanna fly out to my place and install them??? its only 17*F here! lovely weather! LOL
but seriously, looks great man.
Aj
This E55 is FOR SALE!!!
So is the C5 Corvette
Pm for details... thanks!
98' Corvette 427ci: 524rwhp N/A
06' Suzuki GSXR 1000: 160rwhp
96' Chevy Suburban: 380rwhp & 450 rwtq @ 8psi
01' E55 AMG: 300rwhp & 333rwtq
1 BAD BURB is offline   Reply With Quote
Old 01-13-2007, 05:52 PM   #3 (permalink)
Dawson AMG
Dawson AMG's Avatar
Date registered: Oct 2006
Vehicle: '01 E55 AMG
Looks great! Does make your pedals look exotic. Are these pure aftermarket or did they come on AMG cars back in 1999-2002? I’m installing the slip on covers for the 2005-2006 AMG cars
Dawson
2001 E55 Brilliant Silver
www.pedenent.com
Dawson AMG is offline   Reply With Quote
Old 01-14-2007, 12:05 AM   #4 (permalink)
carcrushin
Date registered: Sep 2006
Looks really awsume....Can you post what site on E-Bay....Will they work on 99 AMG........................
carcrushin is offline   Reply With Quote
Old 01-14-2007, 02:27 AM   #5 (permalink)
omeyhomey
Aj
ya i did it in 42 degree weather today hehe, and at my altitude freezing is at 37 so my toes & fingers were numb after the 2 hours it took lol
Old 01-14-2007, 02:28 AM   #6 (permalink)
omeyhomey
no they were not options back then but they look so OEM that you could never tell. Everyone does the slip covers so i wanted to do something different but the slip covers are a great alternative if you dont wanna do all the work. Thanks for the comments
Old 01-14-2007, 02:32 AM   #7 (permalink)
omeyhomey
yes these will actually work on almost all mercedes. Most mercedes after 1993 have almost identical pedal boxes with a few minor alterations here and there but for the most part they are all pretty much the same so these should actually be able to fit any MB (infact i installed a similar set on my S320 W140 back in the day. I have attached pictures of them isntalled on my S320, they are the diagonal slat design AMG pedals, both are nice but the dotted ones loook more modern so i put those on the AMG. either look great).
Yes they will work on 99. thanks again
Old 01-14-2007, 02:38 AM   #8 (permalink)
omeyhomey
hey guys,
In order to make it easier for you to find some pedals i have included a few links...
eBay Motors: MERCEDES AUTO PEDALS HAND BRAKE +FREE LETTER EMBLEM (item 190069781274 end time Jan-17-07 02:54:16 PST)
The ebay seller i bought it from was "BMWMB" he just had a bunch up a week ago but i guess the auctions ended, as soon as he has them listed up again I will put more links in this thread. Its best to buy his all-in-one kits that have all the pedals + shift knob + emblem... its the best deal by far. anyways hope that helps guys
VVVVVVV (attached picture of the kit i got for $99 + $25 shipping) VVVVVVVVVV
Old 01-14-2007, 12:41 PM   #9 (permalink)
omeyhomey
oh yea, if you have a bad back this mod may not be for you lol.
Old 01-15-2007, 10:54 AM   #10 (permalink)
JOE55
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
LOL
JOE55 is offline   Reply With Quote
New Brushed Aluminum AMG pedals arrived today :) omeyhomey W210 E50 AMG, E55 AMG 23 08-18-2006 09:49 AM
Wanted.. AMG or OEM aluminum pedals. gbmotorsport For Sale, Trade & Wanted Items 4 06-09-2006 06:43 PM
Brushed Aluminum Roof Rails albowwow W163 M-Class 7 07-18-2005 06:05 PM
AMG Aluminum pedals and foot rest Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 07-09-2002 09:15 AM
AMG Aluminum Shifter & Pedals - Where to Buy? RK W163 M-Class 1 10-16-2001 11:05 PM
