Idler Pulley/Tensioner Pulley Noise - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 11-18-2012, 12:31 AM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2002 E55 AMG
So after removing my belt, decided to check all the pulleys... here are two videos... Now what blows my mind is why would the tensioner pulley make that noise at 101k? It's the updated version. And both of them spin freely. The tensioner has maybe half a millimeter of play. I'd tighten it, but don't know the torque spec since it's the updated tensioner. Could it be possible someone tried taking the belt off using the tamper proof torx bolt?
Thanks guys!
IMG_2028.mp4 video by Nocturnal-G | Photobucket
IMG_2029.mp4 video by Nocturnal-G | Photobucket
2002 E55 - Daily Driver
BMC Filters - Resonator Delete - Magnecor 8.5mm Competition Wires - Slotted AMG Cryogenic Rotors - Akebono Ceramic pads - Black AMG Monoblock II's - AMG Flathood Badge - LED City Lights/Plate Lights
Nocturnal-G is offline   Reply With Quote
Old 11-18-2012, 04:49 PM   #2 (permalink)
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
If it's the Updated version" but the China knockoff - not Litens - then tensioner could be going again. The China made tensioners are sh*t.. A OE Litens is like $120 on the internet and a 20 minute job to put your worries behind you
fabbrisd1 is offline   Reply With Quote
Old 11-19-2012, 03:39 PM   #3 (permalink)
Thank you Fab! I just checked and it seems the litens version is plastic whereas mine isn't yet is the updated design. I bought the car with that, interesting to see what kind of tensioner it is... Perhaps the reason mine is failing so soon is from heat issues. I shall buy the Litens unit! And a new idler pulley for preventative maintenance.
Old 11-19-2012, 03:52 PM   #4 (permalink)
Do some reading on that idler pulley install... that bolt goes on forever when you go to pull it out, requires loosening up or removing the fan...
Good luck - I know all will be well !
Old 11-19-2012, 04:48 PM   #5 (permalink)
Thank you Fab! I'm ordering both pulleys tonight.
Old 11-19-2012, 09:12 PM   #6 (permalink)
Date registered: Oct 2007
Vehicle: '03 Z4, '02 E55
Do some reading on that idler pulley install... that bolt goes on forever when you go to pull it out, requires loosening up or removing the fan... !
Regarding removal of that extremely long bolt, I also was challenged. But after struggling with how to remove the fan, I came up with another idea. Using a Dremel tool, I removed just enough of the plastic fan blade, near the hub, to ease the bolt out. After replacing, I removed 1/2 the amount from the two blades on the opposite side. I don't think I could be but a couple of grams out of balance, if that. BTW, I used a semi-circle shape cut-out, eased the corners, no notching.
Unless there's an easy way of removing the fan, this is the fastest, easiest way that I could see.
Just my way of coping with this issue.
Good luck.
Mike K.
Mike K. is offline   Reply With Quote
Old 11-20-2012, 06:50 AM   #7 (permalink)
So after looking at all the tensioner pulleys available on the market, I believe the one on my car is made by Trucktec... It's a metal pulley with the hex bolt to relieve tension. Don't know much about the brand but I have a Litens unit on the way with an INA idler pulley as well. Anyone know if the fan comes off for the tensioner pulley removal as well? I looked at it and I think I can do it without removing the fan, as for the idler pulley... I'm going to remove two of the allen bolts holding the plastic fan to the clutch, and swivel the third to the point where I can maneuver the fan to remove the bolt.
Thank you to everyone for the suggestions! Does anyone know the torque specs on the bolts? If I remember correctly the tensioner bolts are 25 nm. Don't know the idler pulley bolt torque spec though... And it's a T50 Torx socket that's needed if I'm correct?
Old 11-20-2012, 11:59 AM   #8 (permalink)
Clarification
Maybe I misunderstood - your tensioner comes with a new wheel/pulley, then you have your idler pulley - the rest of the junk turning/running the belt are mechanical stuff.
See pdf's ..
Old 11-20-2012, 04:11 PM   #9 (permalink)
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
You are correct, leave the last bolt in but loosen it and swivel the fan out of the way or just take the whole thing off via the large nut.
Eric Cantona quotes
When the seagulls follow the trawler, it is because they think sardines will be thrown into the sea.
SHAUNE55 is offline   Reply With Quote
Old 11-20-2012, 05:33 PM   #10 (permalink)
What would everyone's preference be on the size of the torque wrench for these bolts? 3/8 or 1/4 drive? I'm leaning towards the 3/8 but at 25 nm that's roughly on the lower end of the torque wrench.
Bookmarks
