» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 10-28-2009, 08:32 AM   #1 (permalink)
Date registered: Jun 2009
E-320, December 1998 Ignition or key issues
Hi,
I have a Mercedes E-320, Elegance, with under 70,000 miles. All is well with the car. However, today the car key while opening the doors and trunk could not move the ignition. As in I placed the key inside and tried to turn. It didnt turn. Tried several times and it did turn once but the cars auto start did not engage (as in the cars auto ignition taking over once u move the key)far enough.
I tried turning the key again but to no avail.
funguy1974 is offline   Reply With Quote
Old 10-28-2009, 08:51 AM   #2 (permalink)
Musikmann's Avatar
Do you hear the ignition unlock when you insert the key? If not, it sounds like something with the ignition. Sometimes they can get dirty so you might try cleaning the contact surfaces inside the ignition tumbler. Also, how healthy is your car's battery? That is what powers the starting procedure. The keys in the battery itself have nothing to do with that process, only for the remote functions.
Old 10-28-2009, 09:03 AM   #3 (permalink)
Ignition.
Thanks. How can I clean the inside Tumbler. No I don't hear it unlock. The battery is good.
Old 10-28-2009, 09:05 AM   #4 (permalink)
Can I spray the ignition with WD 40, or some other cleaner?
Old 01-05-2010, 07:49 AM   #5 (permalink)
Date registered: Nov 2008
I have the same issue with my 2001 E55. After the vehicle is locked when I unlock it and try to start it 9 times out of 10 the ignition will not turn, I then have to pull the key out and replace it until I hear the ignition unlock. If I do not lock the vehicle 9 times out of 10 it works fine. I have the car at an authorized Mercedes mechanic, since I only have one key fob they are saying to try a new one to see if this solves my problem. I know key fobs are expensive but a new ignition will cost a ton. Any help would be appreciated.
JFAD1 is offline   Reply With Quote
Old 01-08-2010, 05:26 PM   #6 (permalink)
Premium Member
DBA-ONE's Avatar
Date registered: Aug 2009
Vehicle: 2000 CLK 320 Cabrio
Premium Member
Sounds like the ignition slot itself. As far as spraying WD40 goes, that sounds like a really bad idea.
Cheers
DBA-ONE is offline   Reply With Quote
Transmission issues on E 320 1998 210 funguy1974 New Member Introductions 3 09-06-2009 05:55 PM
AC issues on E-320 1998 210 funguy1974 New Member Introductions 3 09-06-2009 12:03 AM
1998 ML 320, Transmission/Speedo issues itplanett General Mercedes-Benz 1 09-03-2009 07:22 PM
E-320 AC issues 1998 210 funguy1974 W210 E-Class 8 07-07-2009 09:50 PM
Multiple Issues on 1998 S-320 BenzsOnly W140 S-Class 3 08-29-2006 09:08 AM
