» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 10-06-2009, 08:31 AM   #1 (permalink)
Date registered: Oct 2007
Vehicle: '03 Z4, '02 E55
Side marker light replacement - challenged
Folks,
It appears our E55's are slightly different than the standard W210 for this procedure.
The manual shows a small access door inside the wheel well for getting to the side marker light. Mine does not have that. However, it does have a small door, facing the pavement, near the fender in the plastic tray underneath.
I've tried going through that, it seems there is a small metal bracket in the way, blocking the socket.
Do I need to remove the tire and wheel, then the plastic inner fender for access?
Thanks in advance for your help.
Mike K.
Mike K. is offline   Reply With Quote
Old 10-06-2009, 08:40 AM   #2 (permalink)
Date registered: Jul 2005
Are you looking to change a bulb or replace the whole assembly?
I had to change one of these bulbs...it was as simple as sliding the lens, and it pops out.
HockeyGod is offline   Reply With Quote
Old 10-06-2009, 09:04 AM   #3 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
Just pry the lense off with a small screwdriver. I used a rag to avoid scratching the paint. The lense pops off with very little pressure. Easy access to the bulb, and a five minute DIY to replace the lense. Good luck.
ruBENZ_00E55 is offline   Reply With Quote
Old 10-06-2009, 10:10 AM   #4 (permalink)
HG and ruBenz,
Thanks !! I knew it had to be fairly simple.
I thought it may be through the lens but didn't want to get overly aggressive.
Thanks also for the quick reply.
Take care.
Mike K.
SIde Marker Light Nuttree W251 R-Class 5 08-13-2009 09:39 AM
Mods Pictures: Low Beam, Parking Light, Tail Light, License Light, Side Marker, ETC bs79 W211 E-Class 12 07-09-2009 02:01 PM
Side Marker Replacement!! Help!! david287c W210 E-Class 2 02-01-2009 05:40 AM
Side Marker Replacement da_guitarist W208 CLK Class 2 03-30-2007 02:08 PM
Where to buy replacement side marker covers for 99 SLK230? copterchris R170 SLK Class 4 12-21-2006 08:10 PM
