Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 07-20-2008, 02:21 PM   #1 (permalink)
Date registered: Jul 2008
aux fans questions
any help would be appreciated i have a 98 w210 e55 and cant get the aux fans to work. the ac works fine after replacing evap temp sensor.
car runs fine but engine coolant temp gets up to the mid to high 90s celsius if left stood . mechanical cooling fan seems ok. if i use the test procedure[hold auto buttons 10 sec] the aux fans come on full speed.
are the aux fans supposed to work as soon as ac is switched on or only when engine coolant temp gets high?
i have had a look at the fan control module under the left headlamp there is 12v in but no power out to the fans, is there any way to test the module
regards
chris
ps no faults are showing on the pushbutton unit on the dash
chris9682 is offline   Reply With Quote
Aux fans JAD W163 M-Class 8 09-29-2007 08:30 PM
Aux. fans battlecat714 W124 E,CE,D,TD Class 17 04-26-2006 06:06 PM
A/C and Aux fans bgang W124 E,CE,D,TD Class 6 10-03-2005 03:11 PM
A/C and aux fans ratherbesailing W201 190E, D-Class 2 08-30-2005 08:22 PM
How to remove the aux fans for AC Guest (MBNZ) W124 E,CE,D,TD Class 1 06-18-2002 06:33 PM
