Hi~
I have a 1997 E420. The auxilliary fans are not running. I looked for a fuse in the engine compartment, inside driver panel and rear seat. I did not find any fuse pertaining to auxilliary fans or any burnt fuses. Is there a fan relay that I would look for, or a different location for the fuse?
thanks, help has always been much appreciated.....
Hi~
Auxilliary fan, do you mean the two fan behind the center grill? if so the passenger side run off the driver side via a belt. It might be a broken belt. If you spin the one fan the other should spin also.
Hi~
