» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 06-26-2008, 11:28 PM   #1 (permalink)
harb's Avatar
Date registered: Nov 2004
Vehicle: 2000 E320
SRS Light Reset?
I recently had an accident that caused the body shop to replace the driver side door. In the process of doing that, they had to obviously disconnect and reconnect the driver side air bag in the door. Now the SRS light stays on. I tried to read faults through an OBDII connector and got none - no faults found. How do I reset the SRS light?
I have a 2000 E320.
Thanks
Tony Harb
2000 E320
1990 300E
1986 380SE
1982 280SE
1977 280S
harb is offline   Reply With Quote
Old 06-27-2008, 04:51 AM   #2 (permalink)
Date registered: Mar 2007
Vehicle: 2001 E55
dealer only reset as far as I know.
FrankiE55 is offline   Reply With Quote
Old 06-27-2008, 03:50 PM   #3 (permalink)
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-
Cool You need to have...
the SRS computer read,
This is from the X connector under the hood ONLY ..
A good indy will do it 4 free, it is really easy and fast.
Or if you have the adapter you can isolate the pin in that connector and diy.
OBTW - In this car, when you correct the fault the light will go off.... except....If your car has been in a wreck, all bets are off, you need the codes read, PERIOD!
B
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline   Reply With Quote
Old 06-27-2008, 04:25 PM   #4 (permalink)
Vehicle: W211/W210wagon/W209
B
On a 2000 W210 the SRS can ONLY be reset Via the OBD2 connection UNDER THE DASH on the drivers side...EARLY W210s Used the 21 Pin Connection inside the fuse box
Any time the SRS light is on it must be reset via The SDS or a Decent scan tool
Mark Cummins is offline   Reply With Quote
Old 06-27-2008, 10:51 PM   #5 (permalink)
harb's Avatar
Vehicle: 2000 E320
I already tried to read the codes using an Actron OBDII scan tool connected to the outlet under the dash on the driver side. It did not read any faults. An earlier reply mentioned that the fault can only be read, and therefore reset, using the connection in the trunk. Which one is it? How can I do it myself if I only had the under-the-dash scanner?
Mark- What is the SDS? Is the Actron OBDII scan tool capable of doing this. If so, how?
If the only choice is to visit the dealer or the mechanic equipped with the under the hood tool, I'll do it. But I want to make sure that I give it a try myself first!
Old 06-30-2008, 07:21 AM   #6 (permalink)
harb's Avatar
Vehicle: 2000 E320
I took the car this morning to an independent MB mechanic and he was able to reset the SRS light from the connector in the fuse box under the engine hood. He didn't charge me anything. He said that the body shop must have unplugged and re-plugged the air bag cable while the car was on at some point during this process, or at least the key was in position 2.
Old 06-30-2008, 09:02 PM   #7 (permalink)
1 BAD BURB's Avatar
Date registered: Aug 2006
Vehicle: 96' Suburban, 01' E55, 98' C5, 06' GSXR 1000
Send a message via AIM to 1 BAD BURB
anyone know how to reset this light in your own garage? or do u need a scanner?
Aj
This E55 is FOR SALE!!!
So is the C5 Corvette
Pm for details... thanks!
98' Corvette 427ci: 524rwhp N/A
06' Suzuki GSXR 1000: 160rwhp
96' Chevy Suburban: 380rwhp & 450 rwtq @ 8psi
01' E55 AMG: 300rwhp & 333rwtq
1 BAD BURB is offline   Reply With Quote
Old 07-07-2008, 04:34 PM   #8 (permalink)
Cool As I said...
If you correct the fault, the light will go off by itself,, UNless it has been in an accident ( or tampered with ).
Again, have the codes read, most will do it for free, that will tell u exactly what the fault is, then diy and fix it.
B
SRS Dash light reset?? skipinschool W210 E-Class 2 06-29-2007 04:09 PM
replaced seat belt, how do I reset srs warning light? Fiery V-Class 6 11-01-2006 03:18 AM
SRS reset steves R170 SLK Class 1 04-20-2006 10:14 AM
SRS reset walking W202 C-Class 1 07-22-2005 01:08 AM
FSS SRS Reset tool joeven W163 M-Class 3 02-10-2005 02:34 PM
