I recently had an accident that caused the body shop to replace the driver side door. In the process of doing that, they had to obviously disconnect and reconnect the driver side air bag in the door. Now the SRS light stays on. I tried to read faults through an OBDII connector and got none - no faults found. How do I reset the SRS light?
Hmmm, from what I know you need the computer. There is a TSB out there for the sensor wires that run in the lower frame that sometime short and cause the SRS fault....
