Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 02-01-2008, 09:04 PM   #1 (permalink)
Date registered: Feb 2008
window stops rolling up SOMETIMES ?!
1999 E320
117,000 miles
My passenger side window wouldn't roll up one night so I started fidgeting with all the windows and was surprised to find out that none of my windows would roll up or down, and it was this way for 2 days. Then one day, I turned the engine on in my car and the windows all started working again. Now 2 days later, I roll my driver's side window down and now none of the windows are working....AGAIN !!! WTF is going on here ?!! The fuses are all fine and I don't understand why it only happens sometimes.
vee833 is offline   Reply With Quote
Old 02-01-2008, 10:09 PM   #2 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
I believe you need to reset your power windows. From memory: If the window is stuck down, (with the key in the on position) try holding the down window position for about four seconds. Then, apply the window up position. If this works, then apply the opposite to the remaining closed windows. If none of this works, use the SEARCH option to find the appropriate method of applying the fix. Good luck.
ruBENZ_00E55 is offline   Reply With Quote
window stops an inch before the top Guest W201 190E, D-Class 3 08-30-2006 01:13 PM
Rolling from LF to RR porky500 W140 S-Class 1 06-09-2006 03:24 PM
Manually Rolling up window Parsifal W126 S,SE,SEC,SEL,SD,SDL Class 2 03-12-2005 04:22 AM
window stops just before top rib W201 190E, D-Class 1 12-12-2004 10:54 PM
Fender Rolling benzo13 R170 SLK Class 3 08-17-2004 10:10 PM
