Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 01-19-2008, 05:09 AM   #1 (permalink)
Date registered: Jan 2008
e55 lowering
hi guys......im new to this forum and im hoping some1 on here can give me some much needed advice. Other forums have not been able to give much advice. ...... iv got a e55amg w210 estate 2001....the rear has self levelling....i need to lower the car but need to find out how to get the rear down.......?????firstly no1 does specfic springs for a estate... but i can get round that...iv got the number 1 pads...but the first thing is to figure out how to bring the rear down.... and advice will be grate....
thanks
e55_animal is offline   Reply With Quote
Old 01-19-2008, 09:40 AM   #2 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
Having owned a late model Lincoln Towncar with a self leveling rear end, I would imagine the lowering procedure would be similar. Remove and/or disconnect the self leveling apparatus, and apply the appropriate lowering springs, shocks, and pads (#1 R; #2 F?). Good luck.
ruBENZ_00E55 is offline   Reply With Quote
Old 01-19-2008, 12:56 PM   #3 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
thanks
I Installed H/R sport springs Front AND Rear on my W210 Estate as they do Not have a listing for the E55 Estate..as the Estate has Springs on the rear..just uses Self level Rear shocks So the E55 SEDAN Springs WILL Fit AND Work
I Also used #1 Pads
Mark Cummins is online now   Reply With Quote
Old 01-19-2008, 08:33 PM   #4 (permalink)
I Also used #1 Pads
That makes sense.
Old 01-20-2008, 04:29 AM   #5 (permalink)
ok...iv heard of people who heav put the sedan springs into the estate...and they work fine...the only difference is the weight,,,,,,,but iv have also heard even if you got the lowered springs in the rear the car still lifts to its self leveling height.......so how do you avoid that?????
thanks for the advice guys
Old 01-20-2008, 10:37 AM   #6 (permalink)
If the front in lowered, then wouldn't that produce an equivalent lower height level at the rear? Also, should the latter not apply, is it possible that the self leveling component is adjustable?
Old 01-21-2008, 02:39 AM   #7 (permalink)
well guess im going to have a look into...but every1 i have approached said dont touch it and leave the car as it is....lol....they make me laugt...i will get round it soon and post some pic of it when its completed
E55 Lowering Links (Front) MD/VA/DC Area Quick E55 For Sale, Trade & Wanted Items 2 05-06-2007 09:47 AM
E55 Lowering Fallbangskid W210 E50 AMG, E55 AMG 11 03-23-2007 12:01 PM
help!!! lowering an 2004 e55 amg greggy W211 E55 AMG, E63 AMG 13 02-02-2007 06:47 PM
BRABUS LOWERING MODULE E55 atan808 W211 E55 AMG, E63 AMG 1 10-17-2005 12:58 PM
Lowering an E55 Guest (MBNZ) W210 E50 AMG, E55 AMG 10 03-03-2001 03:52 PM
