Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 12-03-2007, 05:19 PM   #1 (permalink)
Heretic E55's Avatar
Date registered: Nov 2007
Vehicle: 2001 E55
"Stupid Question" What is the right tire pressure?
Hello all! This may seem like a stupid question, but I have to ask.I have an E-55 with 18's on it. The tire sidewall says "51 PSI max inflation". Are you supposed to inflate to the max? If not, what is the basic formulation (50% of max, 60% of max?). I have always filled mine within 5 Psi of max.Anyone have any idea what standard practice is? Thanks for any help! Brian
Heretic E55 is offline   Reply With Quote
Old 12-03-2007, 05:25 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, heretic, welcome to the forum.
I generally apply the useful knowledge of whatever the owners' manual says. For my non-AMG variant there are two different specs depending on whether you'll be driving sustained high speeds.
It's also if I'm not mistaken the inside of the fuel door.
The only time I would deviate from that would be if I noticed unusual tire wear (center wearing faster, over-inflated, edges wearing faster, under-inflated).
So long as you have the proper-spec tires (particularly for minimum load rating) you can safely adopt the logic of the MB engineers when they designed your car and use the manual's recommendations.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 12-03-2007, 05:26 PM   #3 (permalink)
peter_02AMG's Avatar
Date registered: Jun 2007
Vehicle: 2002 E55 AMG
Look inside your fuel door. The infomation is in there. I set my @ 34psi front /37psi rear.
It doesn't matter what size wheel you have, air pressure is the same inside regardless of size.
peter_02AMG is offline   Reply With Quote
Old 12-03-2007, 07:02 PM   #4 (permalink)
Vehicle: 2001 E55
Thanks for the replies. Thanks for the warm "welcomes" too! The tires on the car are not the original equipment. Does this make a difference in regards to what it says in the owners manual or door panel? I guess my question should be: How much air should you put into a tire that reads " 51 psi max inflation"? Or is it more relevant to use the owners manual guidelines even if the tires are not original equipment?Thanks again, Brian
Old 12-03-2007, 07:24 PM   #5 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Check the psi tire chart in the fuel door location; check your owners manual.
JOE55 is offline   Reply With Quote
Old 12-03-2007, 07:26 PM   #6 (permalink)
Date registered: Jun 2003
I always run 34-35 front, and 30-32 rear for maximum traction, 37 is too high IMO and you will be sacrificing grip. hope that helps.
omeyhomey is offline   Reply With Quote
Old 12-03-2007, 10:08 PM   #7 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
The "51 psi max inflation" is just that: the absolute maximum that should ever be in that tire for safety purposes. "max" has NOTHING to do do with what should actually be put in the tires under practically all driving situations.
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
Old 12-03-2007, 10:18 PM   #8 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
The fuel door specs recommend 32 psi front, and 33 psi rear. I run mine at 33 psi front, and 34 psi rear. The latter seems to be the perfect compromise between traction and roll resistance.
ruBENZ_00E55 is offline   Reply With Quote
Old 12-03-2007, 11:07 PM   #9 (permalink)
Vehicle: 2001 E55
I definately need to let a little air out then. Thanks for all the good feedback. Regards, Brian
wheel/tire question for the "track stars" ... OJwerks R170 SLK Class 13 12-22-2006 02:35 PM
Winter Tire Question 17" vs 18" Omnipotent R171 SLK Class 3 11-01-2006 04:51 PM
tire pressure on 20" geralmjcj W163 M-Class 7 07-02-2006 11:59 AM
tire pressure on 20" geralmjcj The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 06-24-2006 10:38 PM
