Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 11-30-2007, 01:23 PM   #1 (permalink)
Date registered: Nov 2006
Newbie 2002 E55, Some Questions
Hey all...just picked up a 2002 E55 this week. Black on black, 45K miles.
A couple questions:
One issue I have is that the rear sunshade is broken. There is a long "arm" or rectangle shaped pole that had a platic ring broken on one end and it was fundamentally cracked off on the other. MB stated that the whole shade needed to be replaced and it would cost $1200 just for the shade. Any ideas?
Also, for winter driving, has anyone just bought tires and switched back and forth between summer and winter tires on the same rims? I have Pilot's on there (which appear to be brand new) and like the stock rims and don't want to upgrade. I don't really see the point of 2 full sets of wheels at $40 for remounting and balancing.
If that is not the case, I did some searching but didn't find much - are there 17" rims that fit on an AMG - I understand the calipers require a special offset.
Thanks,
Tom
pearsth is offline   Reply With Quote
Old 11-30-2007, 10:07 PM   #2 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
Your recently acquired E55 is also your recently acquired princess. Two words: High maintenance. But she is worth it. (1) You can pay the stealership (though an independent MBZ shop may charge less), or you can DIY (do it yourself). If you choose the latter, here is a recent link that may aid you: http://www.benzworld.org/forums/w210...ade-stuck.html (2) I live in sunny CA where winter is not an issue. However, I am under the impression the Michelin PS2's will get you through the winter. Someone with winter driving experience may correct me if needed. (3) I believe our stock 18" rims were designed to clear our larger AMG brake setup. FYI, front are 18X8:245/40/18;(offset)ET31, and rears are 18X9:275/35/18;(offset)ET35. Aftermarket rims require a great deal of detail, or precise specifications. Welcome to the forum, and good luck with your new princess.
ruBENZ_00E55 is offline   Reply With Quote
Old 12-01-2007, 09:00 AM   #3 (permalink)
Ugh! Don't tell me that. I have been consistently fooling myself that this will be as solid as a Honda!
Anyway, being a former Land Rover owner, I know all about the care and feeding, and visiting the chat boards often to find solutions vs. the dealiership. I have a "hooptie" car sitting on the driveway to use as a parts run car or bad weather vehicle.
Thanks for the tips.
Tom
Old 12-03-2007, 09:01 AM   #4 (permalink)
Eraser-X's Avatar
Date registered: Jan 2005
Vehicle: 2002 E55
Send a message via ICQ to Eraser-X Send a message via AIM to Eraser-X Send a message via Yahoo to Eraser-X
I have Pilot AS on my 02 with 50% treat left on them and they are pretty slippery in just cold rain here in TX. So if you live somewhere with snow get snow tires you can try to limp though the winter with what you have but why? Your spare is a 17 and the smallest wheels and tire the factory could fit over the front brakes so that should be your starting point for another set for winter use.
I would get a second set of wheels and tires for winter the polished rims on the stock wheels will require a lot of cleaning in the winter time so get some cheap one that are already damaged to using in the snow.
Eraser-X
06 R350 with sport package
02 E55 Black on Black with all options
91 Range Rover GDE
8X 280TE
53 356 Cab
Eraser-X is offline   Reply With Quote
Newbie E55 Maintenance Questions Scud E55 W211 E55 AMG, E63 AMG 4 11-12-2006 10:47 AM
2002 E55 newbie TWallace General AMG 5 11-11-2006 12:56 AM
2006 E55 //// Newbie Questions kmode W211 E55 AMG, E63 AMG 2 07-24-2005 12:56 AM
Newbie questions - 2002 G500 rkoesler G-Class 3 12-17-2003 02:46 PM
Questions about 2002 E55 Guest (MBNZ) W210 E50 AMG, E55 AMG 3 11-04-2001 07:01 PM
