Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 11-24-2007, 12:15 AM   #1 (permalink)
Date registered: Aug 2007
Vehicle: 2002 E55 Soon to have C43 too
Ride Clearance Limiter...Has anybody heard of this...
I have been looking around and came across a Ride Clearance Limiter from lorinser along with a spacer kit for the front end. Any knowledge on either of these two would be great. I have never heard of a ride clearence kit. I am gonna be installing 19" wheels all around with a 245/35/19 in the front and 295/30/19 in the rear. Sock spring pads are still on alone with stock suspension. Any problems that i might run into. 1 BAD BURB: i know that you did that 295/19 set-up, have you had any problems?!
papinboo is offline   Reply With Quote
wheel clearance? shipliketheboat R129 SL Class 0 01-10-2006 09:26 PM
valve clearance elgatoensombrero General Mercedes-Benz 1 12-03-2005 03:01 AM
Clearance Witsend W126 S,SE,SEC,SEL,SD,SDL Class 4 01-14-2005 11:26 PM
height clearance GM3 G-Class 4 11-10-2004 06:52 PM
Tire Clearance Heavyd The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 07-14-2003 01:28 PM
