Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 11-13-2007, 08:35 AM   #1 (permalink)
Date registered: Oct 2007
Should I get a transmission flush?
I know there's a couple of threads about this already, but none of them really had any worthwhile results posted. My car has about 56,000 miles on it, which is about the mileage that you would get a normal automatic flushed. I know that these cars have 'lifetime fluid' but from what I've seen when an auto manufacturer says lifetime that means after 100k miles you're SOL.
Has anyone here had a flush and fill performed on their E55? Did it make the car shift strangely? I would like for my transmission to last for more than 100k if possible.
roybotnik is offline   Reply With Quote
Old 11-13-2007, 10:51 AM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Dealer recommend ATF to be change on Service B Plus @ 50K.
JOE55 is offline   Reply With Quote
Old 11-13-2007, 11:06 AM   #3 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
A well maintained transmission will always outlive a well maintained engine. I had mine drained and refilled at 40K. She shifts beautifully. Do it. Your vehicle will thank you.
ruBENZ_00E55 is offline   Reply With Quote
Old 11-13-2007, 11:39 AM   #4 (permalink)
peter_02AMG's Avatar
Date registered: Jun 2007
Vehicle: 2002 E55 AMG
I had my AT oil & filter change by MBZ dealer. charge me about $360 for the job. They told me they use synthetic oil but I think they are full of crap!! I looked up the part number they used and it just reg MBZ ATF oil. I told them but they kept saying it synthetic oil
Transmission shift a little smoother. I didn't notice much different. but still need to be replaced, nothing is "life time"
peter_02AMG is offline   Reply With Quote
Old 11-13-2007, 05:11 PM   #5 (permalink)
Thanks guys, I will get it flushed asap.
Old 11-13-2007, 10:31 PM   #6 (permalink)
Dawson AMG's Avatar
Date registered: Oct 2006
Vehicle: '01 E55 AMG
Yes replace the trans fluid. MB trans fluid is synthetic! If you are using a flush oil system in your trans and not a drain do not do it. Have filter changed and drain cooling lines you will only get about 6 QT out this way. In 10,000 miles drain at trans pan plug 3 QT. or keep draining oil until it looks very red in color. After I drained and replaced filter trans worked just as before GREAT I did change at 40,000 miles. I will drain pan plug and top off at 60,000. Enjoy
Dawson
2001 E55 Brilliant Silver
www.pedenent.com
Dawson AMG is offline   Reply With Quote
Old 11-14-2007, 10:26 AM   #7 (permalink)
Are you sure MBZ ATF oil are synthetic??
I check the part number on the the oil they use and it didn't say anything about synthetic on the lable?
can anyone verify that MBZ AFT is in fact synthetic oil?? thanks
Old 11-14-2007, 12:06 PM   #8 (permalink)
Yes, that would be good to know. Should I just drain and refill this myself instead of getting it fully flushed?
Old 11-14-2007, 04:26 PM   #9 (permalink)
OEM MBZ AFT is part #001-989-2103-10 which is synthetic. What part # did they use?
Old 11-14-2007, 04:31 PM   #10 (permalink)
... Should I just drain and refill this myself instead of getting it fully flushed?
Only if you are experienced. There is no room for error. I have the experience, and I still let the dealer do it.
Transmission Flush NorCal_ML320 W163 M-Class 5 03-07-2006 11:31 PM
transmission flush jtbeche W208 CLK Class 6 01-21-2006 05:21 PM
Transmission flush poll Daniel W163 M-Class 18 10-25-2005 11:38 AM
Transmission Flush and Fill jinsoojoo W203 C-Class 2 08-24-2005 08:33 PM
Transmission flush? AlBoston W163 M-Class 2 04-27-2003 11:08 PM
