» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Closed Thread
Old 10-31-2007, 07:31 PM   #1 (permalink)
Date registered: Apr 2005
How to repair the AC system
Assuming this works, attached are 5 of 15 files that contains PDF pages from the offical MB workshop on how to:
Replace the compressor
Replace the dryer
Replace the expansion valve
Also included are oil capacities when replacing all components or individual parts such as just the expansion valve.
I will forward the other PDF's in two other messages.
This works for any W210 chassis - mine was a E430 2000 year model.
I used these instructions recently to repair my A/C system that required these three parts above. Note that it says to remove the fan when removing the compressor. It is possible to slide the belt out around the fan without removing the fan itself.
The reason there are so many PDF's is becuase some of the MB instructions call out other instructions that have their own document. Basically you can change out any of these three parts in any order - just follow the logic in the MB instructions.
good luck
jnash is offline
Old 10-31-2007, 07:33 PM   #2 (permalink)
How to repair the AC system Part 2 of 3
here are the PDF's 6-10 (11-15 of 15 files) to follow in next message
jnash is offline
Old 10-31-2007, 07:35 PM   #3 (permalink)
How to repair the AC system Part 3 of 3
Here are the last set of PDF files 11-15
jnash is offline
Old 11-01-2007, 01:13 AM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Jim,
Thanks so much for posting it here, I'll add this to our DIY Section and Sticky.
Regards,
-JOE55
JOE55 is offline
Closed Thread
Dr. ColorChip Paint Chip Repair System Pepper Detailing and Car Care 6 11-25-2007 06:04 AM
Command System Repair Shop needed TCrook W210 E-Class 0 10-02-2006 12:42 PM
Pictorial on how to diagnois and repair your glow plug system. DieselGiant.com W123 E,CE,D,CD,TD,TE Class 2 09-20-2005 03:04 PM
Pictorial on how to diagnois and repair your glow plug system DieselGiant.com W126 S,SE,SEC,SEL,SD,SDL Class 0 09-20-2005 06:25 AM
Climate Control/HVAC System Repair kentbelt W123 E,CE,D,CD,TD,TE Class 0 06-22-2005 08:21 PM
