Hi, everyone. I brought my 01 E5. Still have an extended warranty until this August and they found both springs broken at the last coil. It was covered by warranty but I want to know if the springs that were installed are for an E55 because the car is much higher in the front, I can see almost all my tread of the tire. Since I had this car it sat level but now it sits higher in the front. I understand that new springs might take time to settle but I wanted to know if the springs for a normal E class W210 is the same as an E55 W210?? And if anyone knows the part number??
Thanks for your help. I guess I have to call them on monday they put
part #210 321 30 04, the seat they must used my old ones because I don't see it on the invoice.
Thanks again. The car does sit level but I remember when I used to coat my tires it was close to the fender now I can wipe them without hitting the fender. I called parts today to confirm the right spring with my Vin # it took him awhile because of all the suspension codes but he came up with the same number the dealer put in my car. Do you think your number is the only one for our E55's???? If your right then they did put the wrong spring.
