Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 07-09-2007, 05:12 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2000 E55 AMG
Clip on bottom of MAS??
what's the trick on unhooking this? I assume thats all that is left after you remove the large plastic retaining ring around the top?
Thanks!
Ritmo2k is offline   Reply With Quote
Old 07-10-2007, 12:10 AM   #2 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Using a flat head screwdriver, carefully pry the clip way from the MAF sensor while pulling the MAF sensor straight up. When reapplying the MAF sensor, the clip will simply snap on.
ruBENZ_00E55 is offline   Reply With Quote
Old 07-10-2007, 07:19 AM   #3 (permalink)
Thats what I thought, but wanted to be sure...
Thanks a ton!
MAS ? Billymb W124 E,CE,D,TD Class 6 07-27-2006 01:45 AM
MAS YOGGI W202 C-Class 4 03-05-2006 09:30 PM
MAS YOGGI W202 C-Class 0 03-02-2006 01:24 AM
WHAT YOU GETTING YOUR ML FOR X MAS? deejaykaygee1 W163 M-Class 25 12-22-2005 04:35 PM
MAS Mod DJ The DJ R170 SLK Class 1 10-11-2002 03:19 PM
