Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 07-07-2007, 03:57 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2000 E55 AMG
Sigh... '00 Mass Airflow Sensor Test
Hey Guys,
Again, I presume the well engineered MAS tanked in my beast. How can I test for this myself? I saw some pinouts and tests for a small C class but don't know if they apply!
Also, whats the best place to get this at?
Thanks!
Ritmo2k is offline   Reply With Quote
Old 07-08-2007, 10:24 AM   #2 (permalink)
r_liebo's Avatar
Date registered: Sep 2006
Vehicle: 2002 E55
Can't answer those questions, but you might want to consider cleaning the sensor before replacing.
You can search this forum for info. It seems relatively easy and certainly cheaper than replacing.
Before the AMG, reverse chronolgy:
MB C320sport, AKA "The Lemon"
BMW 325ci
BMW540i Sport
Porsche Boxster S
BMW 328i
BMW 318is
Ford Taurus SHO
Toyota Supra Turbo
BMW 733i
Schwinn 10 speed
r_liebo is offline   Reply With Quote
Old 07-26-2007, 03:55 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Ritmo, I don't know of any test for it, if the codes are in the system, you replace it. Or you can try cleaning it first as noted, there is a pictorial DIY on removing the insert to clean it in the main 210 forum under the DIY sticky thread.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 07-26-2007, 09:24 PM   #4 (permalink)
leomd's Avatar
Date registered: Jan 2007
Vehicle: 2000 E55
You can purchase from Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips (about $ 214) or you might be able to find cheaper on ebay - IMO your better off buying a certified new oem, you always get what you pay for.
Definitely try cleaning first with CRC MAS cleaner - they often get fouled by silicon used to seal electronics on the unit itself.
good luck
2000 Silver E55
2003 Range Rover
leomd is offline   Reply With Quote
Old 07-26-2007, 10:32 PM   #5 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Scan the beast: eBay Motors: MERCEDES BENZ S CLASS OBD-II CODE SCANNER DIAGNOSTICS (item 280136157492 end time Jul-27-07 20:07:52 PDT)
If you get codes 0170; 0173, you need a new MAF sensor. Good luck.
ruBENZ_00E55 is offline   Reply With Quote
Old 07-27-2007, 08:49 AM   #6 (permalink)
Hi,
Actually now I am getting P0130 errors... In your expereince is safe enough to just replace that O2 sensor or should I also look elsewhere for causes?
Thanks!
Old 07-27-2007, 09:19 AM   #7 (permalink)
Originally Posted by Ritmo2k
Hi,
Thanks!
0130; 0133 errors indicate O2 sensor is kaput or soon to be kaput. Replace the sensor.
Old 07-27-2007, 09:39 AM   #8 (permalink)
Thanks bud, I'll order one today!
Old 07-29-2007, 12:56 PM   #9 (permalink)
Hey ruBENZ_00E55,
0130 suggests Bank 1 sensor circuit, so which of the 4 snesors do I replace
Thanks!
Old 07-29-2007, 10:11 PM   #10 (permalink)
Hey ruBENZ_00E55,
Thanks!
As defined in my manual:
0130 - G3/4 (O2-CAT front right)
or
0130 - Right O2 sensor before CAT (G3/4)
Possible Mass Airflow Sensor ripoff? gregs210 General Mercedes-Benz 9 08-11-2007 12:55 PM
New MASS AIRFLOW SENSOR MAF AIR MASS METER $1 97e320auto For Sale, Trade & Wanted Items 2 04-22-2006 04:56 PM
Mass airflow sensor in C230 samgupta General Mercedes-Benz 2 12-29-2005 07:39 AM
Mass airflow sensor install. supersparker W208 CLK Class 2 06-10-2005 08:04 AM
i didnt have to buy a mass airflow sensor!!!! seckid R170 SLK Class 6 08-16-2004 10:06 AM
