Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 06-30-2007, 12:05 AM   #1 (permalink)
Date registered: Jan 2003
Vehicle: 2000 E55 / 2003 G500/ 2004 M3
Window Regulators # $ % !!
Sucks - just lost BOTH rear window regulators in the period of two weeks. Replacements are on EBAY @ $ 50 each, I'll provide the labor (great write up on the W210 string).
Wouldn't you think MBZ would have figured power windows out about 20 years ago ??
Weird ...
2000BEAST is offline   Reply With Quote
Old 06-30-2007, 01:35 AM   #2 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
Don't use the rear windows: you're just asking for it!
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
Old 06-30-2007, 08:12 AM   #3 (permalink)
Cool
Man - thats a helluva note - dont use your rear windows because they will break. The weird thing is that this car has been PERFECT up till now, with this exception.
If I rationalize, I suppose thats not bad, but still sucks just the same.
Old 06-30-2007, 05:14 PM   #4 (permalink)
Date registered: Jun 2003
i agree, i always left my child locks on after first one broke.
omeyhomey is offline   Reply With Quote
Old 07-01-2007, 11:08 AM   #5 (permalink)
leomd's Avatar
Date registered: Jan 2007
Vehicle: 2000 E55
i just lost my right rear regulator a few weeks back....compared to my Rover with tranny glitches and other electrical mishaps - I can deal with the window regulators going. Once you do one regulator you will get the learning curve up to about 1 hour of labor per door.
Just one suggestion - use aluminum rivets not the steel oem ones...as they are easier to put in and drill out the next time it goes
good luck
2000 Silver E55
2003 Range Rover
leomd is offline   Reply With Quote
Old 07-02-2007, 03:06 PM   #6 (permalink)
Vehicle: '98 E430
I used self tapping metal screws. They work just fine.
NOLA430 is offline   Reply With Quote
Old 07-05-2007, 08:11 PM   #7 (permalink)
Date registered: Jul 2007
I have had similarly bad luck with my E320 rear window regulators. They are easy to replace, but they really are aggravating when they break. Out of curiosity, was it hot and/or sunny when your blankity blank regulators failed?
60bugeye is offline   Reply With Quote
Old 07-05-2007, 09:42 PM   #8 (permalink)
DasRheingold's Avatar
Vehicle: 2000 E55
Nature of plastic, gets weak with age, motors still strong, back windows dont get much use. My brother use to work for Toyota and he said he has done hundreds of them, same problem. As of right now my rear right is being held up with a stick in a door, waiting for the right part, they sent me one for the left.
No man with a good car needs to be justified
DasRheingold is offline   Reply With Quote
Old 07-07-2007, 03:26 PM   #9 (permalink)
Hot sunny day both times. Think that the previous post is probably correct - MBZ chose their plastic supplier unwisely. Too bad there wasn't a "latent defect" law (10 years) for "known problems" with cars... window regulators are definately bs in our cars, and MBZ knows it, but they are off the hook after the warranty expires.
PS - stealer quoted me $ 585 (per side) to repair , the EBay parts I ordered are right varound $50. If they are not going to offer an extended warranty repair, they could at least offer a reduced repair rate instead of FULL boat. How much business do you think I'm going to give to them in the future ?
Old 07-07-2007, 05:31 PM   #10 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Don't give them anything!
JOE55 is offline   Reply With Quote
Window Regulators desperadoresearch W124 E,CE,D,TD Class 1 11-03-2006 01:32 PM
What is up with the Window Regulators? chandlerGTi W126 S,SE,SEC,SEL,SD,SDL Class 3 11-10-2005 03:55 PM
89 300E Window Regulators rdsomers W124 E,CE,D,TD Class 3 10-08-2005 02:46 PM
Power window regulators Guest (MBNZ) W140 S-Class 2 05-18-2002 03:08 PM
window regulators Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 0 11-09-2001 10:27 AM
