Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 06-24-2007, 03:09 PM   #1 (permalink)
E55_GT3wheels's Avatar
Date registered: May 2004
Vehicle: W210 E55,E320,C240
rim question
Does anyone know if the following size will fit a W210 E55 (lowerd with H&R and blistein sports)?
FRONT: 8.5JX19, offset 35mm, 225/35/19
REAR: 10JX19, offset 25mm, 265/30/19
Thinking about swapping wheels...
E55_GT3wheels is offline   Reply With Quote
Old 06-24-2007, 09:16 PM   #2 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
Assuming the rim design clears our bigger brakes, I do not foresee any mounting issues with the given offsets or rims widths. In terms of tires, though the best fit for a 8.5JX19 rim is 255/35/19; I would recommend: 245/35/19, and live with the exposed 0.39 " gap at the lip of the rim. The 255 tire may run into front suspension nut. At the rear, the best fit for a 10JX19 rim is a 285/30/19. But again, my research indicates that a 285 at the rear of our vehicles is too much grip, and extremely prone to fish tailing. Here I would recommend a 275/30/19 for the optimum section width contact. And again, with a 0.39" exposed gap at the lip of the rim. Note: That both your proposed section widths (225/265) would leave an exposed 0.78" (over 3/4 of an inch) gap at the lip of their perspective rims. Also, neither proposed tire would sit safely running those rim widths. If MBZ got anything right, it was our stock section widths (245 F/275 R) on the optimum rim widths (8 F/9 R). Aftermarket wheels must be extremely precise for the perfect fit. As far as the addition of your dropped suspension, I would venture to say, "It's going to be a close one."Just my two cents. Good luck.
ruBENZ_00E55 is offline   Reply With Quote
Old 06-27-2007, 04:08 AM   #3 (permalink)
Date registered: Jun 2007
I Have 245/35/19 on front and 285/30/19 on rear with no problems I also have a 2001 e430 they ride like day and night the 430 smooth e55 rough on bumps
benzzn55 is offline   Reply With Quote
rim question... lonelyboi909 W210 E-Class 6 06-13-2007 01:07 PM
18" 19" 20" Rim question e430Mercedes W210 E-Class 5 12-01-2005 08:41 PM
A Rim Question Ruffrob The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 11-18-2005 12:56 PM
rim question anoc320 W203 C-Class 7 09-24-2004 09:26 PM
have a question about my rim rk3685 W208 CLK Class 3 09-18-2004 06:25 PM
