Originally Posted by AdamY Dear all,
I was able to close the windows with my infra-red remote control of my 1992 300SE, but couldn't do the same thing with my 1999 E55. Does the W210 have this feature? How to program it to do so?
Cheers,
Adam |
It seems that you need to re-sync your power windows, sunroof..etc. did you recently change your car battery?
Synchronizing Head Restraints:
If the power supply was interrupted (battery
disconnected or empty), the head restraints are no
longer adjusted automatically. To resynchronize the adjustment feature, turn electronic key in steering lock to position 2, move the seat completely forward and the head restraint fully down, and hold respective buttons for approximately two seconds.
Synchronizing power windows:
disconnected or low), the windows cannot be opened or
closed by the Express feature. To resynchronize the express feature, press <close> side of power window switch to resistance point until the window is completely closed and hold for additional 2 seconds. Repeat procedure for each window. The automatic full opening and closing procedure of the windows should now be restored.
Synchronizing sliding/pop-up roof:
disconnected or low), or if the sliding/pop-up roof is blocked during closing/opening procedure, the system has to be synchronized. To do so, turn electronic key in steering lock to position 2, move and hold switch in direction (3), until the sliding/pop-up roof is completely raised at rear, and
hold for additional 1 second.
Synchronizing ESP:
disconnected or empty), the BAS/ESP malfunction
indicator lamp may be illuminated with the engine
running. Turn steering wheel completely to the left and then to the right. The BAS/ESP malfunction indicator lamp should go out.
Synchronizing remote control:
The remote control may have to be resynchronized, if
the vehicle cannot be locked or unlocked. To synchronize insert electronic key in steering lock.
The remote control should once again be operational.
