Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 03-01-2007, 10:08 AM   #1 (permalink)
E55Cent's Avatar
Date registered: Apr 2005
Vehicle: 99 E55
Rear brake caliper fell off, could of died.
I was driving up the coast to a customer yesterday when all of a sudden I heard a horrible noise coming from the left rear of the car. I was thinking I had a flat tire so I start to pull off the freeway on to the next exit. I was going about 85mph when I hit the brakes and SH*T there was no brakes. I blew through the stop sign at the top of the exit and almost drove right off the bridge. I soon gained control of my car and came to a stop on the side of the frontage road. I jumped out of the car to find my rear brake caliper mangled and dragging on the ground. Also I noticed my HRE wheel was leaking air. I guess when swinging the caliper hit the center of my HRE and broke the center valve stem. My car is still on the side of the road because I don't even want to deal with it. The part I dont understand is rear brakes havent been touched in 2.5 years. It seems weird it took that long and 50k of miles to come loose. The sad part is my other car "Mini Cooper" is also in the shop getting 7k worth of motor work done. Any way I thought I would just share my story.
Mario
99 MB E55
HPS Gen I supercharger custom pulley
EvoSport lightened pullies
CoolingMist chemical cooler 50/50 Meth/H2O
H&R Sport Springs w/ #1 MB pads
Koni adjustables
K&N Filter
Removed Res and Magnaflow muffler
Lorinser roof wing
Upraded H.I.D. Crystal "face lift" head lamps
Brabus Shifter and flat hood emblem
All Black Emblems
19" staggered HRE 448R
2 12" Infinity Subs
E55Cent is offline   Reply With Quote
Old 03-01-2007, 11:07 AM   #2 (permalink)
paulunm's Avatar
Date registered: Nov 2002
Vehicle: 2000 E55 AMG
Wow! That's not good! Please let us know if the mounting bolts broke, or came loose, or other! I'll check mine soon...
paulunm is offline   Reply With Quote
Old 03-01-2007, 11:23 AM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Sorry to hear about what happen to you and to your brakes and HRE rims glad you're okay Bro!
JOE55 is offline   Reply With Quote
Old 03-01-2007, 12:11 PM   #4 (permalink)
audioslave's Avatar
Date registered: Jun 2006
Vehicle: 02 E55
WTF....glad to hear you came out OK. The $$ on the wheel and new caliper is cheap compared to getting t-boned blowing a stop sign. Hope you had a clean pair after that!
I had one of my caliper mounting bolts fall of my rear caliper (long time ago) on a Mazda. So the caliper was flopping around on the one bolt. Made a horrendous noise….but I still had some brakes. It was entirely my fault. Taught me to check those three times after every brake job!
I’m curious about the lack of bakes….did the pistons come out of the caliper? Was it the loss the brake fluid and pressure or some interference by the ABS/Stability system that caused the lack of any braking power?
mike
audioslave is offline   Reply With Quote
Old 03-01-2007, 12:40 PM   #5 (permalink)
SaMaS's Avatar
Vehicle: E55 ///AMG
Send a message via MSN to SaMaS
glad you ok Mario, sorry to hear about it hope everything will work out ok.
SaMaS is offline   Reply With Quote
Old 03-01-2007, 02:08 PM   #6 (permalink)
haister's Avatar
Vehicle: 02E55
Glad you are OK Mario! let's know what you find out on your caliper, that is scary.
haister is offline   Reply With Quote
Old 03-01-2007, 02:45 PM   #7 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
not to hi-jack but welcome back Haister!!
Old 03-12-2007, 04:50 PM   #8 (permalink)
haister's Avatar
Vehicle: 02E55
Mario,
How are you doing? what is the latest with you and your car???
Old 03-12-2007, 06:05 PM   #9 (permalink)
E55Cent's Avatar
Vehicle: 99 E55
Originally Posted by haister
Mario,
just pick up some new rotors and brake pads. But I just noticed I need those tiny little pins that hold in the rear pads. It should be back on the road tomorrow but with a spare tire. The HRE rims is being fixed right now.
Old 03-12-2007, 06:08 PM   #10 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
how did it fell off again?
Tighten torque for rear brake caliper mounting bolts? allerton W126 S,SE,SEC,SEL,SD,SDL Class 5 11-02-2006 06:52 AM
Rear brake caliper goburgie W126 S,SE,SEC,SEL,SD,SDL Class 2 01-17-2006 06:42 AM
brake caliper mbrenneman Vintage Mercedes-Benz 5 05-16-2005 12:29 PM
rear brake caliper rebuild -need help johnhon W124 E,CE,D,TD Class 6 12-10-2004 04:19 PM
Need C32 rear brake caliper specs MaxCooper W203 C32 AMG, C55 AMG 2 09-15-2002 10:15 AM
