Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 02-28-2007, 04:35 AM   #1 (permalink)
Date registered: Apr 2006
Brake disk question
So, my car is approaching 33K. I am thinking it is almost Brake disk/shoes replacement time. So I've been looking around, $240.00 per disk is the cheapest I've found. Does anyone know any place that might save a guy a buck on some disks? Did any of you guys just use the same disk with new pads...or did you replace them? I know they can't be resurfaced...
2000 W210 E55
Tacjam is offline   Reply With Quote
Old 02-28-2007, 10:21 AM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
When you get your rotors turned they will tell you if they can be turned or not.
The safest answer for MB service reps and many others is to support the premise of do not turn rotors... but a MB rotor can in many cases be turned down a bit without hurting anything.
DIY Link:
http://www.benzworld.org/forums/atta...-diy-brake.pdf
JOE55 is offline   Reply With Quote
Old 03-01-2007, 01:26 AM   #3 (permalink)
Thanks
DIY Link:
Thanks a million for that write-up! I was under the impression that AMG rotors were to thin to be turned due to weight. Mine have a slight lip...not to bad at all for 33k. I'll pull one off have it measured to see if they can be turned....which btw would be great and save me a bunch of money. So any recomendations on some pads? Looking for something with less brake dust than stock.
Old 03-01-2007, 11:21 AM   #4 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
The pads I'm currently using Mintex I ordered it through Bekkers Imports, it has minimal brake dust like axxis and porterfield.
Old 03-02-2007, 02:33 AM   #5 (permalink)
Thanks again Joe!
Jim
Brake disk replacement Supercharged SEC W210 E50 AMG, E55 AMG 5 07-02-2005 08:34 AM
Replace brake rotor disk Ekless W210 E-Class 7 07-21-2004 01:38 AM
Replace F/brake pad and disk stevepow W126 S,SE,SEC,SEL,SD,SDL Class 5 06-09-2004 06:02 PM
Brake disk corrosion + sound when braking prasanna W210 E-Class 2 04-01-2004 12:54 AM
Brake disk Warped petermerle G-Class 5 07-04-2003 12:28 PM
