Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 02-26-2007, 05:14 PM   #1 (permalink)
SaMaS's Avatar
Vehicle: E55 ///AMG
Send a message via MSN to SaMaS
incase someone looking for S/C
was looking thru ebay.... eBay Motors: HPS Supercharger Mercedes ML55 ML 55 AMG ML500 (item 290087295707 end time Mar-05-07 16:58:28 PST)
I have nothing to do with sale...
SaMaS is online now   Reply With Quote
Old 02-26-2007, 11:20 PM   #2 (permalink)
Date registered: Jun 2003
wow thats cheap... but im a NA diehard i want 400HP the old fashion way
omeyhomey is offline   Reply With Quote
Old 02-27-2007, 05:44 AM   #3 (permalink)
SaMaS's Avatar
Vehicle: E55 ///AMG
I'm sticking with ya omeyhomey !
Old 02-27-2007, 09:53 AM   #4 (permalink)
E55Cent's Avatar
Date registered: Apr 2005
Vehicle: 99 E55
getting 400 crank hp is one thing but 400whp is another. I'm very happy with my Generation 1 supercharger. It is the best part of my car. People are always amazed by the sound and power of my car. The HPS Gen 1 systems is good but stay away from the Gen2 it is a nightmare that you will never wake up from
99 MB E55
HPS Gen I supercharger custom pulley
EvoSport lightened pullies
CoolingMist chemical cooler 50/50 Meth/H2O
H&R Sport Springs w/ #1 MB pads
Koni adjustables
K&N Filter
Removed Res and Magnaflow muffler
Lorinser roof wing
Upraded H.I.D. Crystal "face lift" head lamps
Brabus Shifter and flat hood emblem
All Black Emblems
19" staggered HRE 448R
2 12" Infinity Subs
E55Cent is offline   Reply With Quote
Old 02-27-2007, 01:18 PM   #5 (permalink)
Date registered: Jul 2006
Vehicle: 2002 E55
E55Cent, can you tell if the pictured SC is the Gen1 or Gen2?
If it is the Gen1, how involved is the installation and tuning? I recall reading that you didn't have the ECU issues that the Gen2 had. Did you have to tune yours at all, or did it adjust on its own?
Thanks.
Tagsley is offline   Reply With Quote
Old 02-27-2007, 01:24 PM   #6 (permalink)
SaMaS's Avatar
Vehicle: E55 ///AMG
Gen II mounts on top of the engine Gen I mounts on the right side(passenger side), correct me if I'm wrong ....
Old 02-27-2007, 01:25 PM   #7 (permalink)
E55Cent's Avatar
Vehicle: 99 E55
Thanks.
It is a Gen 1 but there might be a ton pieces missing. This kit was made for the ML and not the E55. It shares about 85% but still there is going to be some differences. The istall is about 10hours or so. The Fuel pump and dyno was another4 hours.
Old 02-27-2007, 01:29 PM   #8 (permalink)
Vehicle: 2002 E55
Thanks guys. I was having dreams of 400hp, but I guess this isnt the way its going to happen.
Appreciate the lightning fast response
Old 03-13-2007, 07:54 PM   #9 (permalink)
Date registered: Nov 2006
Vehicle: 2002 E55 AMG
E55cent, I just got perhaps the last Gen I made installed on my 2002 E55. We are having some trouble with it and was hoping perhaps that you could give me a detailed account of any problems you experienced on the install.
I had to change out the idler pulley as there was too much belt slippage so we went from 90mm to 110mm. That helped but did not really solve the rough running. it starts, it runs, it screams when you step on it, (3 Beemer guys hanging around trying to pretend they didn't care, nearly died at the dyno when we opened it up) but a smooth, steady acceleration causes a rough spot in the high 2000 range that disappears shortly after if you just keep accelerating through it. also off the line it is rough, even stalled once. Adam at HPS suggested a vacuum leak but we have already checked boost and it held steady. It is only producing 2lbs of boost and RWHP to 345 from the 302rwhp we measured on the baseline before install.
I would also like to talk to you about the lightened pulleys since HPS recommends zero mods to the engine when adding the Gen 1. My shop is a hardcore racing shop that specializes in fuel injection and carburation system, and has said we will build a fuel management system from scratch if he has to but I keep thinking this should work as designed and that we are mssing a couple of minor things in the setup.
Looking forward to your reply,
Integrator1
integrator1 is offline   Reply With Quote
Old 03-14-2007, 08:35 AM   #10 (permalink)
Date registered: Jan 2003
Vehicle: 2000 E55 / 2003 G500/ 2004 M3
Integrator1
and so it begins !
E55Cent is really the only guy I have ever heard say nice things about HPS. And even then, it sounds like he spent a ton of time and $$ on his own to dial his blower in, with little support from HPS. Betcha that he is a better reference than HPS for your project - but good luck just the same.
2000BEAST is offline   Reply With Quote
incase of emergency? Chaw W123 E,CE,D,CD,TD,TE Class 1 07-24-2006 06:29 AM
Incase Bin Laden is a BW troll........... deathrattle Off-Topic 47 01-21-2006 08:07 PM
Glowplugs - incase you are interested MercedesMax W123 E,CE,D,CD,TD,TE Class 4 01-18-2003 09:31 AM
