I finally had the chance to take the front wheels off to determine the spacers being used. Let me preface this by explaining where I was logically. I bought my car in Jan of this year, already lowered, so I have no real history on what has been modified and with what parts. It had an Avantegard shift knob, I'm hoping and assuming it has the Avantegard package.
Based on the way my car sits, I though was riding on #1 spring pads and some form of aftermarket spring/shock combo which lead to the rubbing issues. After reading various columns, my next project what to change the spring pads to #2 up front and issued resolved.
Now today, I notice a tear on the tire along the inside edge about a foot long, no air/pressure loss. I bust out the jack to replace the tire and take a moment to finally inspect the equipment. To my surprise, I am on stock #3 spring pad (OEM) and all I could make from the the shocks was they are bilsteins and the number I could make out was "BE32710T0". So now my ideas/questions are:
1. after reading through a bunch of forum threads, the model number does not look familiar with those posted/recommended. I concerned that the parts were not design for the vehicle. The car seem to ride pretty well except for the tight corners where the rub usually occur. Do I need to change the spring/shocks/pads? I concern the shock may be too soft and there is too much play in its movement.
2. the rubbing on the inside seem to be due to the control arm or the suspension nut, is this common amoungst e55's?
3. I'm assuming that going up to a #4 pad may resolve this problem. I'm running Michellin PS 245/40 R18, will the additional 4mm doesn't seem like it will solve the prob.
4. I was along considering wheel spacers to provided a little more buffer to the suspension nut and/or control arm.
5. Also considering a camber kit that will push the wheel away from the culprits.
I'm kinda confused on where I should go from here. What I thought would be a minor spring pad switch now has me possible modifying the spring/shocks/pads. Your suggestions/advice would be greatly appreciated. Thanks.
