Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 02-05-2007, 08:38 PM   #1 (permalink)
Date registered: Jul 2006
Dash light flickers when turn signal
Hi, everyone. When I put my turn signal on my centre display where the mileage is flickers too with the turn signal. I still have MB extended warranty but just want to know if it just a bulb because it's been awhile that the small screen where the gear selecter display on the dash has a few lines missing and sometimes I don't know what gear I'm in. Should I have them change the whole dash? Can they input the correct mileage if they do replace the whole instrument cluster?
Versace is offline   Reply With Quote
Old 02-06-2007, 09:53 AM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
I think your pixels gone bad, I'm not sure if MB is going to change the whole dash for you and yes they will put the correct mileage for you.
Take care & enjoy the ride,
JOE55
JOE55 is offline   Reply With Quote
Old 02-14-2007, 08:12 PM   #3 (permalink)
so I'm going to pick up my car tomorrow and the dealer replaced the cluster under warranty but the milage will read 000000. They replace my ball joints which were covered but I don't know why they replaced them without me authorizing? I also asked them to check my fuel gauge because it wasn't reading full when I filled it so they said they replaced the sending unit. But one thing that I really wanted done and they said it isn't covered is my trunk won't lock with the key and they said the cylinder is not covered and I am a little pissed off. Are the other things they replaced for me a common issue with this car again it's an 01 E55
Old 02-15-2007, 10:33 AM   #4 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
Did you ask them why it would read 000000 and not the current mileage on your engine?
Old 02-15-2007, 09:38 PM   #5 (permalink)
No I never asked them why. I will go tomorrow because we had a snow fall here yesturday in toronto so I will go and pick it up tomorrow.
SRS light and Turn Signal Horus R129 SL Class 0 11-14-2006 11:57 AM
Clear Turn Signal Light Malone W124 E,CE,D,TD Class 1 09-01-2005 11:15 PM
turn signal and tail light covers wwv01 G-Class 3 12-16-2002 04:45 PM
Turn signal stays on (solid light) Chas G-Class 6 04-17-2002 01:54 PM
Mirror turn signal light bulbs Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 6 02-05-2002 03:40 PM
