Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 02-05-2007, 03:30 PM   #1 (permalink)
E55Cent's Avatar
Date registered: Apr 2005
Vehicle: 99 E55
Getting too much boost, sometimes.
I'm running between 5.5 to 6.0 psi under full boost, but there are times when I'm passing another car under very light load at about 3k rpm's when I see 8 to 9psi. It is very strange but under full load I never go past 6psi even when I'm spraying Methanol. Anyone have any ideas why?
Mario
99 MB E55
HPS Gen I supercharger custom pulley
EvoSport lightened pullies
CoolingMist chemical cooler 50/50 Meth/H2O
H&R Sport Springs w/ #1 MB pads
Koni adjustables
K&N Filter
Removed Res and Magnaflow muffler
Lorinser roof wing
Upraded H.I.D. Crystal "face lift" head lamps
Brabus Shifter and flat hood emblem
All Black Emblems
19" staggered HRE 448R
2 12" Infinity Subs
E55Cent is offline   Reply With Quote
Old 02-05-2007, 06:55 PM   #2 (permalink)
Date registered: Jan 2004
Send a message via Yahoo to coolcarlskiC43
Mario
Could your belt be slipping under full throttle Mario?
W202 AMG C55 4.3 to 5.5L conversion 310whp 324wtq
coolcarlskiC43 is offline   Reply With Quote
Old 02-05-2007, 07:33 PM   #3 (permalink)
1 BAD BURB's Avatar
Date registered: Aug 2006
Vehicle: 96' Suburban, 01' E55, 98' C5, 06' GSXR 1000
Send a message via AIM to 1 BAD BURB
boost creep??? but i thought that only happens in a turbo due to a failed waste gate...
belt slipping is not the issue, you wouldn't get any boost then.
Mario, does it spike to 8 or 9psi, or does it stay up at that level?
Aj
98' Corvette 427ci: 524rwhp N/A
06' Suzuki GSXR 1000: 160rwhp
96' Chevy Suburban: 380rwhp & 450 rwtq @ 8psi
01' E55 AMG: 300rwhp & 333rwtq
02' Subaru WRX: 245awhp & 267awtq @ 20psi
1 BAD BURB is offline   Reply With Quote
Old 02-06-2007, 03:00 AM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 1999 E55 AMG
Send a message via AIM to IanE55
Does the HPS supercharger kit use a Eaton Roots style blower, or a twin screw style supercharger. With a roots blower, it is possible to have higher boost at mid range loads, because of the way air is compressed.
Let me know if you want me to go into detail.
IanE55 is offline   Reply With Quote
Old 02-06-2007, 04:35 AM   #5 (permalink)
suicidal4life's Avatar
Vehicle: 2001 E430
The HPS Gen1 system uses the Eaton(magnuson) MP90 which I'm sure you know is a modified roots design.
Even if E55Cent is not interested I personally would be interested in hearing more detail about what causes the higher boost.
suicidal4life is offline   Reply With Quote
Old 02-06-2007, 10:17 AM   #6 (permalink)
E55Cent's Avatar
Vehicle: 99 E55
It is an Eaton roots but these blowers are not classified as copressors like a Vortec, or twinscrew, but rather an air pumps. I'm not sure if my car has always done this and I just noticed or it is someting new. I have modd'd the kit a lot to get the power and safetly I needed. As of now I'm pushing 400whp and 420wtq
Mario
Old 02-06-2007, 06:18 PM   #7 (permalink)
Date registered: Jun 2003
Your catalytic converters may be failing causing severe backpressure which in turn will cause your boost readings to spike. Stock cats are probably having trouble coping with the SC for the long term. I bet the cats are starting to partially melt or corrod causing severe backpressure, you may want to make sure thats not the issue, PLUS its a fantastic excuse to get high flow cats . Here are some great possible upgrades, metal cat is the best @189, vibrant is super free flowing but they look ugly and are not the highest quality construction, and the $99 are metalic cats but i cannot tell if they are 200 or 300 cell cats, they look like 300 cell as to metalkat compared to the vibrant which is definitely 200 cell. hope that helps
eBay Motors: Metal'cat Catalytic Converter High Performance 2.5" (item 230076263906 end time Feb-08-07 12:31:29 PST)
eBay Motors: 2.5" Stainless Vibrant Metal Core Catalytic Converter (item 120075070840 end time Feb-12-07 20:48:59 PST)
eBay Motors: High Flow Catalytic Converter Metal Core (item 8072416113 end time Mar-01-07 18:50:52 PST)
omeyhomey is offline   Reply With Quote
Old 02-07-2007, 04:45 PM   #8 (permalink)
E55Cent's Avatar
Vehicle: 99 E55
I wonder, but my cats are prettiy new, they have about 40k on them. They blew at 78k and the dealer replaced them for free, which is great because they wanted $4500 each. ouch!!!
Old 02-07-2007, 11:49 PM   #9 (permalink)
well 40k is low for cats then gain u are pushing rediculous amounts of air out of that engine. Realistically its probably not cats then if they are that new (however always a possibility when running boost). U think that perhaps maybe its the gauge or sensor itself thats bad and boost is running just fine? Do you have a wastegate on your SC setup or not (i know most done, but some do).
Old 02-08-2007, 10:33 AM   #10 (permalink)
E55Cent's Avatar
Vehicle: 99 E55
The gauge seems to be working fine, I even tested it in a friends truck. The Eaton supercharger has a by pass valve that lets air pass through the blower when the car is not under load. I guess I would be more worried if I was hitting 8-9psi when I have the gas pedal all the way down, but it's only at 1/3 throttle.
Boost Gauge SLKRoadster99 R170 SLK Class 7 07-05-2005 04:51 PM
boost? how much? krk230 R170 SLK Class 1 07-20-2004 04:41 AM
Boost Q Pej D. R170 SLK Class 5 12-02-2002 07:22 PM
I got boost!!!! Periokid R170 SLK Class 5 02-09-2002 08:26 AM
anyone know more about a "boost control"? my friend said it will increase my boost to maybe 10 psi a RAVEr R170 SLK Class 3 10-01-2001 05:51 AM
