Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 02-04-2007, 06:02 PM   #1 (permalink)
b5audia4's Avatar
Date registered: Jan 2007
Vehicle: 2002 E55 ///AMG
W210 E55 Wheel Fitment: 18" OZ Chrono 5x112 ET35
Just picked up a 2002 E55 and will need to get some snow tires. Need some confirmation from you guys.
I have a set of 18" OZ Chrono 5x112 ET35 from my old A4. From the searches, these should also fit the E55 right? Audi and MB share the same offset for a lot of models.
If so, this would save me some cost in getting another set of rims. Can anyone confirm?
Thanks
(Will post pic once I have delivery)
b5audia4 is offline   Reply With Quote
Old 02-04-2007, 09:07 PM   #2 (permalink)
Date registered: Apr 2006
Thanks
W210 wheel packages are PITA. If I were you, I would just take off a front and back wheel to see if your wheels will fit...no rubbing, brake problems ect...I don't think anyone here has put Audi wheels on their Mercedes. I think if I replace my wheels I will have a shop do it locally, so I don't have to order wheels then by chance they don't fit have to send them back. But honestly, these cars are touchy with wheel fitment.
2000 W210 E55
Tacjam is offline   Reply With Quote
Old 02-04-2007, 09:51 PM   #3 (permalink)
b5audia4's Avatar
I went on the tirerack website and based on their configurator, the 18" wheels available (from BBS, OZ) for the 2002 E55 all have 5x112 and ET35 or ET31 offsets. Which is exactly what I have on the 18" OZ Chronos.
I will definitely have a tire shop test fit my old wheels before buying the tires.
Old 02-04-2007, 10:42 PM   #4 (permalink)
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
A W210 E55 has an offset of 31MM front and 35MM rear. As long as your 35MM offset OZ rim design clears the stock 13.1 AMG brake setup up front you should be fine. The real issue is the choice of tire that is to be mounted on your OZs up front. Others have had rubbing issues with M PS2s and GY GS-D3s on aftermarket 35MM front rims. The problem is a suspension nut which sits a few MM's away from the stock wheel. One can barely fit a finger between them. I was fortunate with my aftermarket 35MM rims, and my choice of Falken FK-451. However the fit is extremely tight. Good luck.
ruBENZ_00E55 is offline   Reply With Quote
Old 02-05-2007, 03:17 PM   #5 (permalink)
b5audia4's Avatar
What tires are you using on your aftermarket rim? 235/40/ZR 18 or 245/40/ZR 18 for the front.
Since I have the rims, I was hoping to make use of them as winters. I will have to get new tires anyways.
Old 02-05-2007, 08:25 PM   #6 (permalink)
Being that my aftermarket front rims are 18X8.5 I would have preferred to use 255/40/18. But, the infamous suspension nut forced me to remain stock: 245/40/18 with a minimal lip exposure. Out of curiosity, how wide are your rim?
Old 02-05-2007, 08:45 PM   #7 (permalink)
b5audia4's Avatar
My 18" OZ Cronos are 18x8. But upon further research, it has the 55.7mm bore (the diameter of the centre hole). Mercedes has a 66.5mm bore. Even though it has the correct bolt pattern and offset, it looks like it won't fit because the bore is too small.
Old 02-05-2007, 08:47 PM   #8 (permalink)
Bummer!
Old 02-05-2007, 08:47 PM   #9 (permalink)
b5audia4's Avatar
Are you using 18x8.5 with 245/40/18 front and back?
As Im looking for snow tires, I prefer to run a non-stagger setup. And tirerack recommends 245/40/18 also. I guess 235/40/18 would work for snows too.
Old 02-05-2007, 09:01 PM   #10 (permalink)
Nope; my rear rim is 18X9.5: 275/35/18.
97 E320 19" wheel fitment help elementdeep The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 09-13-2006 02:31 PM
This wheel ok ? R18 et35 200$*4 IGOR 500SE W126 S,SE,SEC,SEL,SD,SDL Class 0 10-28-2004 02:50 AM
Please help; 19"x8.5", et35 with 235/35 fit SLK? Pic! slknv R170 SLK Class 4 12-02-2002 01:42 AM
BBS RSII 17"X7.5" 5X112 ET20mm, which MB will these fit? red96m3 The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 11-28-2002 02:10 AM
Please help! BBS 19"x8.5" ET35, fit on my SLK? slknv The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 11-10-2002 02:50 AM
