two things on the ebay projector headlights. First off is they are the DEPO brand they are good quality, the rest aren't very good. Second, you will need to replace the projector with a much sharper crisper Hella projector or one of the other OEM projectors for maximum perforamnce. I hear light output is not very good with the "stock" projectors it comes with, other then that quality of construction is very good.
I would only buy the the Depos one that are for HID. The other company's are junk. You will need to change out the lens with a 211 E55, BMW X5, Audi RSX or Acura TSX
You total cost will be around $900 with a lot of your own labor. If you want to make them have the spoke looked you can put the lens cover film from STICKERCITY.com. this will aslo protect against rocks and chips.
Mario
99 MB E55
HPS Gen I supercharger custom pulley
EvoSport lightened pullies
CoolingMist chemical cooler 50/50 Meth/H2O
H&R Sport Springs w/ #1 MB pads
Koni adjustables
K&N Filter
Removed Res and Magnaflow muffler
Lorinser roof wing
Upraded H.I.D. Crystal "face lift" head lamps
Brabus Shifter and flat hood emblem
All Black Emblems
19" staggered HRE 448R
2 12" Infinity Subs
$900 seems pretty high, you should be able to get it done for $600 doing your own labor.
Well the lights are about $450 and the right lens are about $250 to $400 plus you have to buy sealers and other small stuff. Also you will need to spend $1100 if you don't have an oven to cook the lights with. LOL
