Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 09-07-2006, 08:36 PM   #1 (permalink)
Date registered: May 2004
Send a message via AIM to philly
Oxygen Sensor Please HELP!
Hi All!
I got trouble codes P0133 and the P0144 on my E420 1997 which are
O2 Bank 1 Sensor 1 Malfunction and No activity.
Could you please let me know wheer I can find DIY step by step instructions on how to install Oxygen sensors or I just need to replace MAF instead.
Please advise. I would really appreaciate your help!!!
THANK YOU!
philly is offline   Reply With Quote
Old 09-08-2006, 11:16 AM   #2 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Originally Posted by philly
Hi All!
THANK YOU!
hi philly,
you don't need to replace your MAF at this time, just replace the O2 sensor.
The two sides of the engine are referred to as banks. Bank 1 contains cylinder #1, the opposite side being bank 2. Sensor #1 is the sensor before the cat. converter(upstream) and sensor #2 being after the cat(downstream.) MAF would not cause the codes you have.
Take care & enjoy the ride,
Joseph
JOE55 is offline   Reply With Quote
Old 09-08-2006, 08:12 PM   #3 (permalink)
Thank you!
Hi Joseph!
Thank you much for your help.
Do you have by the chance pictures of exact location?
Thank you!
Old 09-12-2007, 05:31 PM   #4 (permalink)
SilverBullit's Avatar
Date registered: Dec 2006
Vehicle: 2000 E55, Silver mostly stock
Send a message via Yahoo to SilverBullit
I am having the same problem but with sensor two on bank 1. I read here on another post that bank 1 was drivers side but i replaced the sensor on drivers side and I still have the light...I think i agree with you that bank 1 is passenger side.
J-rod
J-Rod's Silver Bullit E55
SilverBullit is offline   Reply With Quote
Oxygen Sensor a204600 R170 SLK Class 7 03-05-2006 10:27 AM
Oxygen Sensor alimayu1972 W163 M-Class 1 02-21-2006 04:30 PM
oxygen sensor mnsr flick W116 S, SE, SEL, SD Class 1 01-29-2006 03:33 PM
Oxygen Sensor Where is it??? vili1982 W124 E,CE,D,TD Class 5 11-30-2005 10:55 AM
Oxygen sensor wagoneer W124 E,CE,D,TD Class 2 05-02-2005 05:16 AM
