Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 08-08-2006, 09:50 PM   #1 (permalink)
Date registered: Jun 2003
E55 AMG weight reduction possibilities
hey guys,
After taking out the rear seat bottom (to check fuses). I noticed it is also the location of the battery as well. I have done many light weight battery conversions so that could be a great way to save a good 20-40lbs (depending on which batter you get) and also that coupled with spare tire removal and jack/tools removal could add up to a significant amount of weight (A good 100lbs+). However it will obviously have an effect on weight distribution, and also there will be less weight on the rear wheels to that may cause slightly more traction problems.
anyways just a suggestion.
omeyhomey is offline   Reply With Quote
Old 08-09-2006, 08:09 AM   #2 (permalink)
Date registered: Jul 2006
I ditched my spare, jack, and tools as well...hopefully I never get a flat. I usually run Optima batteries in my vehicles. I wonder if the MBZ battery can be replaced with one of those?
-Jeremy
02 MBZ E55 AMG (0-60 in 4.9, 13.5@104mph)
91 Syclone #434 (0-60 in 3.7, 11.95@112mph)
07 GSX-R 750
mrweelr is offline   Reply With Quote
Old 08-09-2006, 11:51 AM   #3 (permalink)
I have a AAA plus membership so i can get flatbed towed anywhere up to 100 miles for free so i never have to worry about that. So i plan on ditching my spare tire, jack and tools nad etc. You can even go more extreme and get the Odyssey battery (weights only 15 pounds). I used it in my M3 for over a year and it worked fantastic. i think 100lbs would really help out acceleration quite a bit but there would be slightly less traction, however im always carrying people around anyways so it may not really matter. another reason i'd like to take some extra weight off the rear axle is that my rear end is slightly lower so by taking some weight out it would even out the height on both front & rear. anyways just a suggestion.
Old 08-09-2006, 04:36 PM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
and if you guys are serious about the weight reduction you can always replace the OEM hood with a CF one...
JOE55 is offline   Reply With Quote
Old 08-09-2006, 05:57 PM   #5 (permalink)
haister's Avatar
Date registered: Jun 2006
Vehicle: 02E55
how much is that?
haister is offline   Reply With Quote
Old 08-09-2006, 06:08 PM   #6 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
Originally Posted by haister
how much is that?
around $800.00
Old 08-09-2006, 07:05 PM   #7 (permalink)
naw i want simple cost effective weight reduction modifications that do not require greatly altering the exterior of the car (along with the cash in my wallet).
Old 08-09-2006, 08:41 PM   #8 (permalink)
haister's Avatar
Vehicle: 02E55
from where? have you actually seen one of these installed on a car in person?
Old 08-10-2006, 10:17 AM   #9 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
Yup I saw one it looks tight especially on a silver color, and Ive seen also a cf hood laminate, nice!
Old 08-10-2006, 06:43 PM   #10 (permalink)
Date registered: Dec 2003
...........yes you can. I have the 25pound odyssey battery. Have had it for 4 months.I was talked out of the 15 pound battery by the seller because of his concern for the cold cranking power in winter. Also no spare tire, no spare tire well, no jacks. Not risk free, but when did you last use your spare tire?
Ted
2003G55
Ted baldwin is offline   Reply With Quote
AMG rims weight and prices Shinigami R171 SLK Class 12 01-19-2006 10:16 AM
The E55 AMG Wagon faster than the E55 AMG Sedan Ghetto2315 W211 E55 AMG, E63 AMG 4 10-10-2005 11:20 PM
After E55 possibilities Crjag W210 E50 AMG, E55 AMG 1 11-08-2003 05:39 PM
E55 Tire Size Possibilities... 2000BEAST W210 E50 AMG, E55 AMG 5 06-06-2003 08:36 AM
What is the weight of a 17inch AMG Wheel? (more) Albert (Vancouver) R170 SLK Class 9 07-19-2001 12:10 PM
