cigarette lighter not working... - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 08-07-2006, 01:50 PM Thread Starter
Date registered: Jun 2003
hey guys,
i did a search but still did not find any good info. I am looking to fix my cigarette lighter it does not light up and does not have power so im thinking it may be a fuse but unsure. where is the fuse located for the cigarette lighter? thanks
omeyhomey is offline
post #2 of 12 (permalink) Old 08-07-2006, 09:17 PM
BNZUOVR's Avatar
Date registered: Jun 2006
Vehicle: 2002 Mercedes E 55 AMG
hey my car has the same problem if i plug in a charger or my ipod unit it powers on but does not light up the cigerette lighter im thinking its the lighter it self.
BNZUOVR is offline
post #3 of 12 (permalink) Old 08-08-2006, 10:21 AM Thread Starter
it seemslike its a very frequent problem
post #4 of 12 (permalink) Old 08-08-2006, 03:13 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Here you go guys about that lighter thingy..
I had the same problem before -cigar lighter inoperative, MB found a shorted Lighter Assembly- parts cost is $25.20 part # 210-820-01-53
JOE55 is offline
post #5 of 12 (permalink) Old 08-08-2006, 04:58 PM Thread Starter
hey guys, I just checked my fuse boxes (2 of the 3, engine bay and rear seat). Turns out my cigarette lighter fuse was blown big time. Its a 15 amp (blue) fuse and the its fuse #2 for those who are curious. If you you have a cigarette lighter problem check #2 b/c thats most probably the culpret. My Radar detector works perfect now . Thx for the help guys
post #6 of 12 (permalink) Old 08-08-2006, 07:46 PM
flapper1's Avatar
For those people whose lighter outlets work with accessories but just pop out the lighter itself, bend those two tabs on the sides down there inwards a bit. Those accesory plugs tend to bend them outward and then they dont make good contact. Just do it with the key off.
flapper1 is offline
post #7 of 12 (permalink) Old 08-08-2006, 08:44 PM Thread Starter
great tip, but ya mine works fine now, radar works great. Im glad i didn't have to take the whole peice out.
post #8 of 12 (permalink) Old 09-05-2011, 09:37 AM
Date registered: Jun 2011
Vehicle: MB ML350
Send a message via Skype™ to mpeak35
Smile Cigarette lighter
Thanks for the info...I have the same problem with the cigarette lighter, it did spark when it came in contact with a metallic object when I was taking out something out of the socket with the keys in...So I will check the fuse ..is it in the back of the passenger side for ML350? Thanks again,,
mpeak35 is offline
post #9 of 12 (permalink) Old 10-24-2011, 07:13 PM
Date registered: Oct 2011
Electrical Plug for back of lighter?
Well, my cigarette lighter isn't working either on my '84 300CD. When I took out the ashtray, I noticed that there is no wire leading to the back of the lighter plug. I assume there needs to be one. I guess I need to take the ashtray housing out to see if it's stuck behind it. Any tips would be much appreciated. Thanks!
mxk2007 is offline
post #10 of 12 (permalink) Old 02-01-2012, 10:49 PM
Date registered: Feb 2012
2006 C230 front cig lighter works fine but the one on the back of the center console is inop...is there a seperate fuse or are they all ran on the same fuse and which fuse is it recommended test to further diagnosis. please and thank you.
louk is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
    cigarette lighter not working / srs malfunction amg123 General Mercedes-Benz 4 05-02-2006 10:33 AM
    cigarette lighter(r) posix W140 S-Class 1 01-31-2006 05:08 AM
    cigarette lighter not working anymore... IFILIIIPIDoIN W163 M-Class 5 08-03-2005 07:15 AM
    cigarette lighter!?!?! malone32 W126 S,SE,SEC,SEL,SD,SDL Class 6 08-12-2004 02:18 AM
    My cigarette lighter is not working anymore. I press it down and it won't hold down.. Jason R170 SLK-Class 7 08-01-2001 10:14 PM
