Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 08-02-2005, 02:10 PM   #1 (permalink)
Date registered: Aug 2005
Vehicle: E55 w210
Tranny Upgrade
Hi my name is Kevin and I am new to this site. I have 2 questions. 1 is are there any good transmission upgrades for a 2000 e55. The second question that i just noticed in my car is that it seems to be louder then it use to be. The sound is more seems like it is getting to much air. It isnt overheating or anything of that sort I was just wondering if it could be an intake or a sensor??
Kevins AMG is offline   Reply With Quote
Old 08-02-2005, 02:27 PM   #2 (permalink)
Fast55's Avatar
Date registered: Oct 2004
Vehicle: 2006 E55, 2005 SLK55, a few others
RE: Tranny Upgrade
Check to make sure your airbox is still connected everywhere. It just pushes in place. As far as beefing your trans, Renntech is the only one I know of. I believe the upgrade is $2,500.00 if you send your trans to them. They add an additional clutch and some other items to increase it's max torque capacity. Shouldn't be necessary unless you're running some type of FI.
Fast55 is offline   Reply With Quote
Old 08-02-2005, 02:51 PM   #3 (permalink)
Vehicle: E55 w210
RE: Tranny Upgrade
well i want to run a kleeman supercharger witha ew camshaft a new ECU and the headers and pipes
Old 08-02-2005, 03:21 PM   #4 (permalink)
Fast55's Avatar
RE: Tranny Upgrade
JamE55 is running the complete Kleemann system and I believe his trans is still stock . So far, so good. Of course, $2,500.00 is a lot less than fixing a grenaded trans and then beefing it, so that's probably not a bad idea if the budget allows. I'm still running a stock trans as well and it's hangin' in there for now.
Old 08-03-2005, 09:41 AM   #5 (permalink)
Vehicle: E55 w210
RE: Tranny Upgrade
alright thanks a lot for the help and im gunna try to fix the problem today and if i have any trouble i gess ill jsut leave a post.
Old 08-03-2005, 05:10 PM   #6 (permalink)
JamE55's Avatar
Vehicle: Hertzmobile
RE: Tranny Upgrade
Kevin,
Pls check PM.[:)]
JamE55 is online now   Reply With Quote
Old 08-06-2005, 11:24 PM   #7 (permalink)
RE: Tranny Upgrade
Kevins AMG - 8/3/2005 10:41 AM
Ditto on that, if you can get a tranny upgrade go for it. I learned the hard way trying to push 950 torque through my Cummins dodge's stock tranny.
dieselpilot1969 is offline   Reply With Quote
