Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 07-06-2005, 03:22 PM   #1 (permalink)
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: CLK430
E55 (W210) / CLK55 (W208) engine differences
Forgive me if this has been previously covered, but the (US spec) E55 (W210) and the CLK55 (W208) appear to have the same block, pistons, crank, rods, heads, and cams. I still have to install my parts CD to confirm those part numbers. However, according to the 2001 press kit, the E55 produces 7 HP and 15 ft-lbs. of torque more than the CLK55 (349 HP versus 342, and 391 ft-lbs versus 376). The main difference I saw was the 2001 E55 uses the Motronic 2.0 system, versus the 2001 CLK55, which uses the later 2.8 system. I thought that was very odd. Why the two different FI systems for the same engine? But then things got more confusing. Do my eyes deceive me or does the E55 really have a different intake manifold and DUAL throttle bodies, versus the CLK55, which has a single??? Then I looked at the 2002 press kit. For the 2002 model year, the E55 uses the newer Motronic 2.8, but it still has the different intake. Anyone know the reason for the differences? Is this true for all W208 bodied AMGs, or do the euro models have dual TB’s? Thanks
MarcusF is offline   Reply With Quote
Old 07-08-2005, 04:42 PM   #2 (permalink)
JamE55's Avatar
Vehicle: Hertzmobile
RE: E55 (W210) / CLK55 (W208) engine differences
Not exactly sure about the Motronic part but the difference in 7HP figures is because of the E55's exhaust system.
JamE55 is offline   Reply With Quote
Old 02-19-2008, 08:49 PM   #3 (permalink)
Date registered: Jul 2006
are you sure it's motronic 2.8? I thought that was for v6 engines?
DynamicS is offline   Reply With Quote
Old 02-20-2008, 02:52 AM   #4 (permalink)
Date registered: Nov 2003
Vehicle: 99 E55 AMG, 83 380SEC, 92 500SL
Its the same engine block/head ... Mounting points are different. but internally they are the same. They both hace
They both have a single throttle body and the airbox/intake is the same.
The power difference came from marketing. the exhaust is different and they dulled down the CLK so it wouldnt cut in to E sales as CLKs were slightly cheaper. Scoff at that if you want but look at the difference between the E and the CLK even now. Huge difference in power.
MSRP 2001 CLK55=67,400
MSRP 2001 E55=70,950
Previous whips
1997 E50 AMG W210, 1986 190E 2.3-16, 1990 230E W124, 1992 400E W124, 1993 190E 2.6, 1983 380SEC, 1997 325iAC, 1995 M3, 1988 325i Cabrio, 1979 320i E21
Looking forward:
2006 CLS55 AMG in 2010
andy380SEC is offline   Reply With Quote
