» Site Navigation » Other Sites
02-03-2005, 03:24 PM
#1 (permalink )
Date registered: Jul 2003
W210 E55 engine into another W210 bodyshell
Hi all
I am wondering if anyone has done a conversion such as dropping an E55 engine and transmission etc into a standard bodyshell such as the E320 etc.
My question is: are the bodyshells the same across the board?
02-03-2005, 04:11 PM
#2 (permalink )
Date registered: Oct 2004
Vehicle: 2006 E55, 2005 SLK55, a few others
RE: W210 E55 engine into another W210 bodyshell
Other than cosmetics, there were a few changes especially at the 99/00 years. To do that, you'd need the motor, trans, ECU, and the entire wiring harness. I wouldn't put that much power into anything without the E55 brakes as well.
02-04-2005, 12:21 AM
#3 (permalink )
Thanks for the reply.
Yes, i have all the parts. its from a 99 E55 AMG.
The bodyshell is from 98 model. will everything drop straight in?
02-04-2005, 09:51 AM
#4 (permalink )
That should work. I'd scavenge all the AMG parts I could, interior, cluster, etc. Good luck and post pics if you can.
02-10-2005, 12:24 PM
#5 (permalink )
Date registered: Sep 2004
You all forgot about the gas tank... Ever wonder why the trunk seems so small in an E55?
02-13-2005, 03:07 AM
#6 (permalink )
yes, thanks for that.
i dont know whether mercedes actually makes the body stronger for the E55 by putting in more spot-welds etc.
02-13-2005, 08:54 AM
#7 (permalink )
BenzWorld W210 Host
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
I thought aout a similar conversion (500 engine) for my E280, but decided against it because the M113 engine would have been too much work. The M109 is alot easier (and personally I think better) but I can't find one in "nearly new" condition.[:(!]
02-13-2005, 08:56 AM
#8 (permalink )
BenzWorld W210 Host
as for the gas tanks, the W210 could be ordered with a "touring" tank which had an increased capacity (an option on all the non V8 cars). I think the touring tank was the same as the V8 tanks, which included the E55.
02-13-2005, 10:54 PM
#9 (permalink )
Well, i did some research and it turns out that they are the same.
The E320 has the same fuel tank size as the E55 which are both 80 litres.
Thread Tools Display Modes Linear Mode
