Help!! I have removed all 6 screws but can not slide out the Glove box to get access to replacing the filters. What am I doing wrong?? the upper end would not give.
IF all the Screws are Removed Push down on the top edge and Pull it out..You WILL Have To Pull Hard to remove it..
It Has Little tabs that retain it on the top edge
Thats why you MUST Push down then pull
Mark, what do you pull on? The glove box door?
I removed 8 screws, including the two plastic ones, but I wasn't so sure you had to apply that much pressure. I mean I pulled so hard I was afraid I would beak something.
