Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Old 12-07-2003, 07:53 PM   #1 (permalink)
Date registered: Jan 2003
Vehicle: 2000 E55 / 2003 G500/ 2004 M3
Lowering Springs...
I want to lower my 2000 E55.The spring pad route is really not what I am after - Objective - 3/4" -1" lower, and slightly stiffer (10%-15%) ride. I am Considering EIBACH.
Any other brands that I should consider - I DO NOT want an overly stiff ride - made that mistake on another car once.
Has anyone been through this exercise before ? What is involved ?
Appreciate your comments based upon experience. THX !!
2000BEAST is offline   Reply With Quote
Old 12-09-2003, 02:10 AM   #2 (permalink)
scorchie's Avatar
Vehicle: CLK55/G500/E55/ML55/etc.
RE: Lowering Springs...
I think in the W210, H&R might be the way to go. Although I find Eibach to be very good too, it just depends on how it feels to you.
There's a guy (tp liquid) that will install them pretty cheap in Nor Cal, he gets recommendations on *.org all the time. Maybe check him out there.
-s-
1987 190E / 1987 300E x2/ 2001 CLK55 / 2001 ML55 / 2002 G500 / 2003 E55 / 2006 R350 / 2006 G450 / 2007 sumtin sumtin
scorchie is offline   Reply With Quote
Old 12-11-2003, 08:03 PM   #3 (permalink)
Problem is..... you dont know how they "feel" until you buy them and install the. Might be an expensive mistake. Anyone know what the ride, and lowering difference is between these two products ?
Old 01-14-2004, 12:38 PM   #4 (permalink)
E55RAT's Avatar
Date registered: Jan 2004
Vehicle: 2000 AMG E55
I just had H&R springs installed on my 2000 E55 and I am happy with the outcome. They dropped my car about an inch and 7/8, It needed one shim adjustment on the right rear to maintain even balance at all four corners. The springs were ony about $238 and the pro install was another $600 or so, plus alignment.
E55RAT is offline   Reply With Quote
