Old 09-11-2003, 05:29 PM   #1 (permalink)
Date registered: Aug 2003
Vehicle: e class
will CL500 amg wheels fit on a w210 96 e320?
guys will stock CL500 wheels fit on a 96 e320?
they are 19x8.5 front and 19x9.5 rear
do u guys know what the offset is? or suppose to be?
w210 is offline   Reply With Quote
Old 09-12-2003, 09:27 AM   #2 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
I think the CL has an offset of 25 where the E has 37 to 41. I think there would be a pro...
I think the CL has an offset of 25 where the E has 37 to 41. I think there would be a problem because of that.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 09-13-2003, 08:55 PM   #3 (permalink)
Date registered: May 2003
Vehicle: '92 500SL
wheel offset
The CL wheels you mention I think have 44mm front and 46mm rear offset. Your E-class would need around 30mm front and around 35mm rear offset with those widths (someone correct if I'm wrong). Wheel bolt holes in CL wheels are also for 14mm bolts.
edon is offline   Reply With Quote
Old 12-22-2006, 09:52 AM   #4 (permalink)
Date registered: Mar 2006
CHECK THIS LINK GUYS... IT SHOULD BE OF SOME HELP AND IF U SEARCH A BIT YOU WILL FIND THAT IT LISTS INFORMATION AND SPECS FOR SEVERAL YEARS AND CHASSIS BENZ MODELS!
http://en.wikipedia.org/wiki/Mercede...ms_and_Fitment
BENZEL WASHINGTON is offline   Reply With Quote
