Changing transmission fluid - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-10-2003, 09:04 AM Thread Starter
Black2000E430's Avatar
Date registered: Jun 2003
Vehicle: 2000 E430
I have a question on my 2000 E430. Do I have to have it service meaning changing the transmission fluid, I was thinking it was a lifetime fluid in there where by you don't need to change it. Please advise.[?][?]
Black 2000 E430
Black on Black
Black2000E430 is offline
post #2 of 14 (permalink) Old 06-11-2003, 12:13 PM Thread Starter
Vehicle: 2000 E430
Re: Changing transmission fluid
The shop who I brought it said it's a lifetime transmission fluid so they just did the service on my engine oil (Synthetic)and everything check out ok
Black 2000 E430
Black on Black
post #3 of 14 (permalink) Old 06-12-2003, 06:24 AM
Date registered: Nov 2002
Vehicle: 97 E420 Sport
It's supposed to be a lifetime fluid but several mechanics I know recommend changing it (a...
It's supposed to be a lifetime fluid but several mechanics I know recommend changing it (and the differential fluid) at 60K. I guess it's a matter of choice but I went with better safe than sorry and had it changed.
aglasgow is offline
post #4 of 14 (permalink) Old 06-12-2003, 11:10 AM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
I Worked for Mercedes and have Seen my fair share of Expired (Late Model)Transmissions ..JUST out of Warranty..COOKED!Burned Fluid.
With NO Help from Mercedes!Lifetime Fluid...Ahh NO!
I Change My Fluid at 30k
Please drain the torque converter and replace the filter ..dont forget to replace the Drain plug crush washers on the Converter and trans pan....Order the tamper proof plug for the filler tube..Little RED Insert.
PLEASE use only the MB fluid
You will need a Dipstick..Since the car does Not have one..And Check fluid level..HOT
Mark Cummins is offline
post #5 of 14 (permalink) Old 06-12-2003, 11:51 AM Thread Starter
Vehicle: 2000 E430
OK Mark, I will take your advise and will let you know. Thanks [:I]...
[:I]
Black 2000 E430
Black on Black
post #6 of 14 (permalink) Old 06-15-2003, 02:40 PM
Vehicle: 1999 E 320
Re: Re: Changing transmission fluid
[Say...do you know if regular anti-freeze is ok for a 99 e320?
PRIMARY12 is offline
post #7 of 14 (permalink) Old 06-16-2003, 02:23 PM
Quoted: 4 Post(s)
I Would Use the MB Oe Coolant..Two Differentcolors a Clear/Orange and a Blue /Colored co...
I Would Use the MB Oe Coolant..Two Differentcolors a Clear/Orange and a Blue /Colored collant are now used by MB.
post #8 of 14 (permalink) Old 02-09-2009, 08:47 PM
Date registered: Feb 2009
Vehicle: 97' E320
Would my 97' E320 also be the "lifetime" ATF? I just turned 100k miles on it this week.
indydad is offline
post #9 of 14 (permalink) Old 02-09-2009, 09:46 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 386 Post(s)
Mine had 100K on it when I changed it. Previous owners had not changed it. As a precaution I had a fluid analysis done by blackstone labs. Conclusion... fluid was well past it's prime, analysis indicated fluid should be changed at Least every 50K miles, contaminates were high. IMHO there is NO transmission made with a "lifetime" fill. Note that automatic transmissions designed for long life (500K-1M+ miles) and extended drain intervals have very large sumps, internal AND external filters, with the external filter usually being changed at least every 25K miles.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is online now
post #10 of 14 (permalink) Old 02-09-2009, 10:00 PM
Vehicle: 97' E320
What was the cost to have the fluid changed?
indydad is offline
