Old 04-05-2003, 03:46 PM   #1 (permalink)
PaulE230's Avatar
Date registered: Apr 2003
Vehicle: E230 (W210)
Brake fluid / Pads worn light.
Very occassionally if I go round a roundabout / corner the fluid warning light comes on very briefly.
The fluid is topped up ok, so it could be the pads are getting low.
But why only when I turning, surely if the pads are low the warning light would come every time I braked?
It has never come on whilst in a straight line whether braking or not.
Any suggestions?
Regards,
Paul.
Silver E230, Galaxy Blue Leather int.
PaulE230 is offline   Reply With Quote
Old 04-05-2003, 04:20 PM   #2 (permalink)
heckflosse's Avatar
Could be a sensor catching?
Could be a sensor catching? They only cost a few pounds from the dealer.
Had a similar thing happen on my old 200, it would some how 'catch' whilst taking a right.
If you take off the wheels you should be able to see whether the pads are worn or if you have a loose sensor. You could even take it to get a free brake test which those Kwik-fit style centres always offer (you don't have to agree to them doing anything!). I would however only use genuine pads, Textar or ATE. You can get them for around £30 a set from www.eurocarparts.com, there might be a branch near you.
heckflosse is offline   Reply With Quote
