I have a 2000 E430 with 17" Bridgestone Potenzas on factory rims. What is the correct air pressure for the 17" with a ZR rated tire? the filler cap says 27 but that seams rather low. Thanks
2000 E430
Bordeaux Red
17" Sport rims
I use 32 PSI all around and works/wears fine.[:D]...
'02 CLK55AMGcab going soon May05
'02 E430SE
'01 CL 600
'94 Mini Cooper German Spec
'72 Morris Cooper S AutoX
'67 Austin Cooper S
'66 MG 1100
'63 Austin Cooper
'04 Denali
I have a 98 E430 and keep all four biscuits at 28 PSI - and they're fine. The pressure ...
I have a 98 E430 and keep all four biscuits at 28 PSI - and they're fine. The pressure isn't too low. However, if you're still uncomfortable with 27 psi, try 30 or even 32 - they'll be fine. During the summer, I'd drop my pressure down about 1/2 psi if you're running around 30+ psi.
