Old 02-02-2003, 06:39 PM   #1 (permalink)
Date registered: Feb 2003
Vehicle: E430 sport
tire problem with E430 sport
I have a 2001 E430 sport package with 20,000 miles and now one tire in the front is completely thread-bare while the other three are same wear. Dealers tells me it the tire, but the tires have been rotated and only now did the tire wear out. Anybody with the same problem?
chestdoc is offline   Reply With Quote
Old 02-05-2003, 04:20 PM   #2 (permalink)
Date registered: Sep 2002
Vehicle: 2000 E320
Could be alignment. ...
Could be alignment.
figure1a is offline   Reply With Quote
Old 02-05-2003, 07:44 PM   #3 (permalink)
Vehicle: ML500, E320 4Matic
Quite possible that that tire has a bad belt that is not running true, but, I would also h...
Quite possible that that tire has a bad belt that is not running true, but, I would also have the alignment checked by your dealer
sosh is offline   Reply With Quote
Old 02-10-2003, 09:56 PM   #4 (permalink)
Darkmann's Avatar
Vehicle: Anything w/Wheels
First things first, check the alignment. I'll bet it's the front passenger side
that's causing the problem. Have them print out the alignment results for you, then make your own conclusion. If alignment has been done, then the tire is the problem.
1989 300ZXT - mine
A pair of running shoes
A 18Hp lawn mower
2 Mountain Bikes
350Z - will be mine when @ 300+HP and 3-Car Garage
Darkmann is offline   Reply With Quote
Old 02-10-2003, 10:05 PM   #5 (permalink)
Vehicle: E430 sport
The alignment had been checked many times. But what is intriguing is that the middle of ...
The alignment had been checked many times. But what is intriguing is that the middle of the tire is bare and not the sides. Also its only one tire after rotations had been done.
Old 02-12-2003, 12:47 AM   #6 (permalink)
cflanza's Avatar
Vehicle: E320/C43/Aviator
Tire is overinflated...
Check the tire presure...
Thanks
cflanza
cflanza is offline   Reply With Quote
Old 02-14-2003, 12:43 PM   #7 (permalink)
Vehicle: MBE430
It appears that you tire is OVERINFLATED. Check the pressure of all four tires - I'm su...
It appears that you tire is OVERINFLATED. Check the pressure of all four tires - I'm sure you'll be able to figure out the problem. If all 4 tires read at or near the same PSI - then you've a bad tire...
cmbenz is offline   Reply With Quote
