I'm new to benz, just bought a 95 E320 with 160k-Km on it. Like what I see so far, but the "Service Engine" light just turned on.
From you technically minded individuals, is there a way for me to query the system? The control module near the battery looks very similar to my volvo's and they can be queryed (insert the ground, turn key on, count the red diode blips.) If this is true, are the error codes of the OBD published on line some place and what number do you ground out?
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
Even a bad gas cap can give you a check engine light so it is hard to determine what cause...
Even a bad gas cap can give you a check engine light so it is hard to determine what caused it to go on without running the codes from the ECU. The dealership is the best place to take it. It could be something minor if the car is running fine with it on. Any of the emmission controls can set it off.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
