I purchased a 97 E420 recently. I am planning to repace the battery and I have been told that The car must been taken to a MB Dealer to reset the computer after battery replacement. Is this correct? This sounds ridiculous!
I recently replaced the battery on my '97 E420 and did not have to do anything except enter the radio code. The radio code instructions are in the owner's manual. It was very easy. BTW, there appear to be two possible batteries listed for the '97 E class so be sure you pick up the correct one.
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
I replaced my battery and all I had to do was put in the radio code. The ECU will relearn...
I replaced my battery and all I had to do was put in the radio code. The ECU will relearn anything that gets erased in the first 50 miles of driving.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
