Just got the mirrors in, does anyone have<br> some advice on installation? For U.S. spec<br> cars, 1999, do I still have to change the <br> adapter on the 2000 mirror to fit the 1999<br> adapter or vice versa. Is it possible to <br> install without removing the door panels?
Dj,thanks for the tips on the tail lights. On the blinking mirror issue, do a search for this on the forum search, this was discussed somewhat recently I believe, and the installation topic was covered on a few areas. Hope this helps.
I took apart my old and new mirrors to look at the motors. My original ones (1996 E-Class) are memory motors and the new ones (2001 E-Class) are not. I saw that the 3 mounting holes were almost the same so I swapped them from the old to the new mirrors. The old motors fit on the new mirrors with only a fraction of a difference. The motor mounts to the mirror glass in exactly the same way. I was able to use the original wire harness this way as well. All I had to change was the socket for the mirror heater and add two wires for the blinker connector.
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
They fit great
Swap the whole mirror but save the wiring. Add a couple of wires for the blinkers and tap in to the taillights.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
