Have your dealer check out the roof guide. Mine got stuck since <br>pieces of the roof lining went on the guide. The switch assumed it<br>was closed since it was stuck. Either they'll replace the roof guide <br>or just clean out the stick pieces that went down. I suggest having <br>them replace the whole thing.<p>Thomas<p>: On '98 E300D, anyone have problem with sun roof controls--not responding? GIFF<p>
: Have your dealer check out the roof guide. Mine got stuck since <br>pieces of the roof lining went on the guide. The switch assumed it<br>was closed since it was stuck. Either they'll replace the roof guide <br>or just clean out the stick pieces that went down. I suggest having <br>them replace the whole thing.<p>Thomas<p>: On '98 E300D, anyone have problem with sun roof controls--not responding? GIFF<p><p>
: On '98 E300D, anyone have problem with sun roof controls--not responding? GIFF<p>Mine would not close.Open all they way then while open push the tilt up switch.This apparently helps switch re set, Mark
