The leak from my rear main seal has finally, after several years, gotten to the point that it just needs to be fixed. Here is my parts list for this job:
Flex disc front kit: 202 410 13 15
Flex disc rear kit: 170 410 01 15
Shifter bushings (2): 202 992 00 10
Shifter bushing clips (2): 000 994 41 60
Front pump seals: 018 997 04 47 and 016 997 14 48
Rear main seal: 112 997 02 46
Rear main seal retainer plate: 112 011 02 08
Rear main seal retainer plate sealant: ???
Transmission electrical connector seals: 001 540 99 81 and 203 540 02 53
Flywheel bolts (8): 004 990 32 12
Rear main seal retainer plate bolts (11): 910 143 006 001
Torque converter bolts (6): ???
Transmission pan drain plug and crush washer: 0000 0000 08 84 and 140 271 00 60
Transmission filter kit: 140 277 00 95
Transmission pan gasket: 140 271 00 80
Transmission pan magnet: 000 988 09 52
Transmission filler tube lock pin: 140 991 00 55
Transmission fluid: 10 quarts
I would appreciate some guidance on appropriate sealant to use for the rear main seal retainer plate. I heard that silicone sealant d 176 404 a2 is good, but am not sure???
Also, I am having difficulty tracking down the part number for the 6 torque converter bolts
HUGE thanks!
HUGE thanks!
