2001 e320 4matic sunroof drain leaking into car
10K views 6 replies 2 participants last post by  keyhole
I have a 2001 e320 in which the sunroof drain is leaking into the car. I took off the windshield pillar trim on the passenger side , and when i had someone pour water into the drain hole the water is dripping from the top of the pillar over the airbag strap an into the car. How do I fix this problem ??
The sunroof drains are via tubes that run from the side gutter corner to exit under the car. Maybe you have a blockage there? Try poking a thin wire up each drain (carefully) from beneath.
However. even if a drain is blocked I am not sure why the water should enter the B pillar. You might have to take off the interior trim to investigate that.
#3 ·
Hi
I was able to thread a thin 3 ft wire from the roof opening down the tube without any problem. Also from under the car I poked a screwdriver up the exit hole with experiencing any resistance. In one test I did see a small amount of water exiting under the car. The problem is that it is dripping into the pillar and down into the car as well. I have taken off the pillar trim and can catch water in a basin inside the car as someone pours water into the drain tube from above.
#4 ·
2001 sunroof drain leaking
Hi
