Hi,
I went today to change my rotors and pads on my station wagon just to find that my rotor on the driver side is frozen.
I tried PB Blaster and some tapping and some pulling to no avail. I would like to try the puller from Harbor Freight Tools and my question is where to place the center pin. The pin (see picture) is pointed and it seems that it would sit in the middle of the hub just prefect. I am not sure though if it is OK to exert pressure on such single spot. I thought about putting some wood with metal across the hub, so the puller does not push into single spot and also once the rotor comes off it will be blocked by such wood block.
Anyway, I was curious if it is meant to be used on the center of the hub, or if I have to go through the hoops and make something else.
Thanks
Thanks
