W210 vibration under braking - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 09-17-2013, 10:58 AM Thread Starter
EFSiR's Avatar
Date registered: Feb 2013
Vehicle: 2001 E430 4 Matic
Quoted: 33 Post(s)
Having troubles chasing the culprit of right side (appears to be the front) vibration that happens under braking. It's not felt in the steering wheel. I changed the front rotors without much help. Lifting the front end and moving the wheels verticaly and horizontaly does not feel like there is any play.
Outer tie rods and lower ball joints have about 50K (km). I inspected the front wheel bearings and those felt tight.
I thought that perhaps it's the rear rotors but those are still looking new.
So what's left is the inner tie rods and upper arms. But, but they feel tight, and again I'm going with the feel I get when moving the front wheels.
Any thougths? TIA
The ultimate ignorance is the rejection of something you know nothing about and refuse to investigate.
– Dr. Wayne Dyer
EFSiR is offline
post #2 of 22 (permalink) Old 09-17-2013, 11:55 AM
71_340's Avatar
Date registered: Nov 2012
Vehicle: No MB right now, 2015 F-150 EB , 2008 BMW R1200GS, 2011 Nissan Juke (wife's), 2000 Jeep (Dobie's).
Lower a-frame bushings are shot......had the same problem on my S320. Replaced the bushings; problem solved!
Not a fun DIY job, if you tackle it yourself make sure you have a good spring compressor and be very cautious! Get it done unless you have experience in doing that kind of work!
71_340 is offline
post #3 of 22 (permalink) Old 09-17-2013, 03:49 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
I have a thread going on same subject and I am also from Ontario.
http://www.benzworld.org/forums/w210...ake-noise.html
This sort of thing has happened before. It is hard to know where problem is. May sound like it is in front when it is at rear. Last time, after changing front disk and pads, vibration was still there. It went away after the rusty edge on the rear disks was ground off. We were on the road and a shop did it for me. Lasted about 5 years, but vibration is back. I am going to change rear disks and pads as a starting point and see if that helps.
I had MB dealer check my front & rear suspension a couple of years ago. They replaced ball joints and tie-rod ends, so I don't think my vibration is suspension related.
MBGraham is offline
post #4 of 22 (permalink) Old 09-17-2013, 08:46 PM Thread Starter
EFSiR's Avatar
Quoted: 33 Post(s)
I've just completed replacement of my front springs and shocks. I did check the lower ball joint (horizontal joint) and it was easily rotated side to side compared to the one on the left. I've inspected the service history and both of them where changed BUT comparing the two, the one on the left would hardly move while the one on the right moved easily. Hmmm, perhaps that was paid for but service was not performed.
My lower A arm appears to be tight. Not sure why would I have to use a spring compressor on my shocks (E430 4Matic) as it takes very little lift of the A arm to remove the bolt from the lower shock. And that's with the new shocks and springs. Got help me if I have to remove the A arm. Those bolts are part of the frame by now with the Canadian winters this car went through.
Good point with the rear brake rotors. Grease monkeys torque the wheel bolts excessively. I understand that any warping can induce vibration which is exacerbated by ABS. It would be a shame as they still look good.
At this point I'm thinking of revisiting the lower ball joint issue.
– Dr. Wayne Dyer
EFSiR is offline
post #5 of 22 (permalink) Old 09-18-2013, 09:10 AM
Date registered: Sep 2013
Vehicle: 1997 s320
don't know from shinola, just passing along what i was told. if you know it's bs, say so.
my 'new' 97 e320 sedan has slight vib when braking hard, seems like left front. broker who sold it to me (distant fam member) told me when discs are hot, running thru cold water will warp them. get the disc machined.
if my pads need replacing machining is part of the job. if not, is there an easy way to tell if the disc is warped?
thanks, st
seekertom is offline
post #6 of 22 (permalink) Old 09-18-2013, 06:02 PM
MBGraham's Avatar
Quoted: 8 Post(s)
thanks, st
See video in Post 6 of this link:
Google should find more info on checking for warpage. I need to check my front and rear.
MBGraham is offline
post #7 of 22 (permalink) Old 09-19-2013, 06:33 PM Thread Starter
EFSiR's Avatar
Quoted: 33 Post(s)
well, I purchased the lower ball joint, got ready to get it off but upon closer inspection, there is nothing wrong with it. Hmmmmmmmmmm. So I'm not replacing it. No need. The ball joint is not as stiff as the new one. It turns 360 deg. easily but other than that there is no play. Upper A arm looks good too.
Interesting to note that the current old ball joint nuts are 21mm where as the new ball joint nuts supplied (at extra charge) are 22mm.
So my next job is to check runout on the rear rotors. If that's OK, then I'll be puting a microscope on my inner tie rods.
– Dr. Wayne Dyer
EFSiR is offline
post #8 of 22 (permalink) Old 09-19-2013, 08:13 PM Thread Starter
EFSiR's Avatar
Quoted: 33 Post(s)
...I did run the car with the rear E brake on for 6km two months ago.(oops) But pulsation started prior to that event.
– Dr. Wayne Dyer
EFSiR is offline
post #9 of 22 (permalink) Old 09-20-2013, 08:21 AM
MBGraham's Avatar
Quoted: 8 Post(s)
I posted this Zimmerman FAQ in another thread, but it is useful reading:
Otto Zimmermann Bremsscheiben GmbH -
MBGraham is offline
post #10 of 22 (permalink) Old 09-20-2013, 02:37 PM
B58
Date registered: Jul 2009
Vehicle: 1997 E320 4 door sedan
I had this problem on my wifes 97 E-320 changed out front pads,rotars with new brgs and races vibration still there.Changed out 2 new rotars on rear vibration gone.The small amount of run out on warped rear rotars was causeing the ABS to slightly trigger at low speeds causeing the very light vibration
B58 is offline
